Old 02-05-2020, 10:37 AM   #15
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Originally Posted by USAFS197 View Post
He's not wrong. I have a strong opinion about decel pops and if I were his tuner, I wouldn't do it for him but, I think this write-up is a good way to still assist. If it's not needed for the clean functionality of the car, I certainly wouldn't make any adjustments to it. Unless the car came from the factory with excessive popping from the exhaust, then I'd tune that out for myself, personally. But I wouldn't ask my tuner to do it.
I will add that the engine in general idles smoother and accelerates better off idle transition without all the negative minimum spark. That is why after you get a tune the pops disappear. So do you want your engine to pop and fart or run more efficiently?
Old 10-08-2020, 12:40 PM   #16
Mike Aruba
Mike Aruba's Avatar
Drives: 2016 2SS
Mike Aruba is offline   Reply With Quote
Old 10-10-2020, 12:21 PM   #17
Jeb114
Jeb114's Avatar
Drives: 2021 300
Popping and cracking means fuel is not burning properly and igniting in the exhaust. Over time this will damage the engine. Low spark condition will create soot in the combustion chamber and cause caking on the valves. Your engine your damage.
Jeb114 is offline   Reply With Quote
Old 10-10-2020, 01:13 PM   #18
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
Not necessarily. To get some pops and crackles, you just have to adjust the timing so that the pressure from the fuel ignition isn't all used to perform useful work. The fuel still burns, you just have some positive pressure shoot out of the exhaust valve. This happens on decels only.
Some turbocharged cars like Hyundai Veloster N actually use this idea to provide anti-lag for the turbo so it spools faster. On an NA Camaro, it will just be for aesthetic purposes.
https://youtu.be/64YzCty-27Y
Sent from toaster or something
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 10-10-2020, 04:05 PM   #19
Zaqwert6
Zaqwert6's Avatar
Drives: 2SS
Back in the carb days yeah, but not today with a stock tune. Nothing getting hurt, manufactured intentional fireworks.
Zaqwert6 is offline   Reply With Quote
Old 03-04-2021, 03:30 AM   #20
MakCamaro
Makis
MakCamaro's Avatar
Drives: 2020 Red Hot ZL1 A10
Great write-up geaux_tigerss!
Old 03-04-2021, 08:36 AM   #21
FarmerFran
FarmerFran's Avatar
Pops and Farts for me!
<Insert Cars You Own Here>
Old 04-07-2023, 11:49 PM   #22
CamaroChriSS
CamaroChriSS's Avatar
Drives: 16 1SS M6 Black -previous 00 Z28 M6
I asked a local performance shop if they could use the spark map from the 19s provided here to tune my 16. They said they couldn’t BUT they could do a “snap crackle pop” tune that would be similar. However, they had the disclaimer that it could cause premature cat failure and they don’t recommend it. Is the way it’s done from the factory different than what one of these tunes would be? I can’t imagine the ‘19+ cars are just being happily cranked out to have shorter cat life.
CamaroChriSS is offline   Reply With Quote
Old 04-08-2023, 12:16 AM   #23
Kerry
Drives: 2019 2SS Camaro
Just a note. when flashing the ecu. After its complete I always go the the scanner and ck for any dtcs set. Sometimes they are, so just clear them. Then push start button, goes out of service mode. Then push it again (no break) wait for 4 chimes then break, push button and start.
Kerry is offline   Reply With Quote
Old 04-08-2023, 01:13 AM   #24
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
I don't think GM would have programmed in the extra snap, crackle and pops at the expense of cat failure, it simply isn't that important...
Old 04-08-2023, 01:17 AM   #25
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
+1 on that write up, one of the best on here!
I understand the negative of pop/bang tunes and wouldn’t want to negatively impact the performance just for it. Though it does make you wonder why GM did it, theoretically the 2019+ are ‘faster’ with the A10 and whatever tune changes they did
2016 1LT v6
- Totaled
Happiness: Infinite
Old 04-13-2023, 10:59 AM   #26
CamaroChriSS
Right? It has to be different than what this performance shop said they would do. However, none of the local Chevy dealers will tune it to the 19 for me. It seems like my best course of action is just to keep searching for performance shops that will actually do the 19 map, and not just their own tune, or figure out how to do it myself at some point
Old 04-13-2023, 11:29 AM   #27
adamjwilson
Drives: 2022 Camaro 2SS A10
Run more efficiently for me! I am working to get all that 'pop and fart' out now.... the exhaust is crazy loud as it is without that annoying popping...
Buy a rice burner with an aftermarket muffler if you want the attention of all that 'popping and farting'
2022 Camaro 2SS/ Whipple 3.0 / 2"Headers/ PRC LTX Heads/ Forged Internals/LT4 fueling/ DSX Aux/
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods
adamjwilson is offline   Reply With Quote
Old 04-13-2023, 01:29 PM   #28
Fstlane
Drives: 2019 Summit White ZL1
Pops and Farts aside....the information on the compare function in HP Tuners is excellent! Just what I needed!
Fstlane is offline   Reply With Quote
