Old 01-31-2020, 11:44 AM   #15
murdamaro
Drives: 2018 Camaro ZL1
Originally Posted by Krowser View Post
Are you saying replace the stock oil pump seal with an LS3 gasket or an LS3 oil pan gasket?
We’re talking about the front main crank seal.
murdamaro is offline   Reply With Quote
Old 01-31-2020, 11:49 AM   #16
murdamaro
Ya, its happened to many of us. Replace it with an LS3 seal and you'll be good to go
Many of us with LT1’s or many of us with both motors? This is a LT4 with a stock lower pulley.
Old 01-31-2020, 12:48 PM   #17
gotswap
gotswap's Avatar
Drives: 2019 ZL1 Crush
Originally Posted by murdamaro View Post
That’s what I’m trying to figure out also, is yours leaking?
No leaks here, how much boost are you running
2019 Crush A10
E-Force 2650
670WHP 615WTQ
All besides the 2650 is bone stock down to the air filter.
gotswap is offline   Reply With Quote
Old 01-31-2020, 02:11 PM   #18
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
You keep saying stock lower pulley, but as gotswap asks, how much boost? What upper? The issue with the seal failing is usually crankcase pressure and has nothing to do with exterior damage from pulling the crank pulley.
Old 08-12-2020, 07:51 PM   #19
Rickdickulous504
Drives: 2018 Camaro ZL1 A10
EDFHobbies-
Hey, if you dont mind. How did you route this set up with both catch cans?
Rickdickulous504 is offline   Reply With Quote
Old 08-12-2020, 08:09 PM   #20
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Here's a pic.. the second can is more for venting not for collection of oil. The normal mighty mouse is routed same as directions.. lift blower and use supplied fitting that directs the pcv valve from going into the blower. Run line from director to in side of can then then out of can to the blower intake. There is all so a vent on the OEM box.
Let me know if you need more pics.
Old 02-08-2024, 11:40 AM   #21
sleepys4
Drives: CT5 BW
Hey man assuming you are still around, any chance you can elaborate on this catch can setup and filters on your clean side separator.
Dealing with a front main seal issue currently and trying to prevent it in the future.
Thanks,
Jordan
sleepys4 is offline   Reply With Quote
2018, front main seal, oil leak, zl1
