Old 01-28-2020, 01:19 PM   #15
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
Looks great
Old 01-28-2020, 06:18 PM   #16
TWG1
TWG1
Drives: 2019 Camaro ZLE
Looks killer. Are those in ZLE offsets? I seem to recall Z28 offsets we’re close, but not same. (Maybe I had that wrong?). Either way, it looks like a perfect fit for you.
2019 ZLE M6
2019 ZL1 A10 (Sold)
1967 Jaguar XKE Series 1 Roadster
2021 F150 Powerboost (on order)
TWG1 is offline   Reply With Quote
Old 01-28-2020, 06:22 PM   #17
Zigg L1
Zigg L1's Avatar
Drives: 2018 ZL1 Garnet Red Tintcoat A10
What size resr tire you running? Do you have spacers? I wanted to run the 315 rear but don't want to add spacers.
Zigg L1 is offline   Reply With Quote
Old 01-28-2020, 07:06 PM   #18
PROMETHEUS
PROMETHEUS's Avatar
295/30/20 and 305/30/20 on 20x10 +23 and 20x11 +43
Old 01-28-2020, 07:38 PM   #19
Firecaptain
Firecaptain's Avatar
Drives: '22 Summit White ZL1 A10
Looks AWESOME! Man that rear tire looks W I D E from that angle!
Did they take much weight and did you go with factory or aftermarket TPMS?
Firecaptain is offline   Reply With Quote
Old 01-29-2020, 10:51 AM   #20
PROMETHEUS
PROMETHEUS's Avatar
Not sure about the weight compared to the OEMs. No TPMS, went with only valve stems. They will take TPMS, just didn't want them.
Old 01-29-2020, 10:56 AM   #21
Scottyz
Scottyz's Avatar
I actually weighed my Z28 rims with the MPS4S. Keep in mind these are factory 19 inch Z28 rims straight from GM. Weighed both fronts and both rears. Should give you guys an idea of what they weigh roughly
Old 01-29-2020, 10:58 AM   #22
Scottyz
Scottyz's Avatar
Not sure of the scale accuracy. I think it is as I have compared my own weight to the weight at the doctors and they were the same every time I go to the doctors.
Old 01-29-2020, 08:48 PM   #23
Zigg L1
Zigg L1's Avatar
I am really liking these Z28 rims. I have been thinking of the gun metal or black color though. Cant decide And some 315/30/20 R888R on the rear. Any pictures of the gun metal on the car out there? Where are you all getting them from?
Old 01-30-2020, 06:02 AM   #24
Cleancoupe
Drives: 18 ZL1 1LE
Just an fyi...the oem z28 wheels are 19s. You can get reps in 20s
Cleancoupe is offline   Reply With Quote
Old 01-30-2020, 07:21 AM   #25
Zigg L1
Zigg L1's Avatar
Yes I was looking at the MRR z28 replicas
Old 01-30-2020, 03:20 PM   #26
Crushed 1LE
Crushed 1LE's Avatar
Drives: 2022 ZL1 1LE
Has anyone installed these on a ZLE? Curious if there are any issues going to 20 inch diameter.
Crushed 1LE is offline   Reply With Quote
Old 01-30-2020, 08:20 PM   #27
Zigg L1
Zigg L1's Avatar
They will fit the same as in the ZL1. You won't be able to run the wider tires as the ZLE. You would have to run the 305/30/20 or 315/30/20. Shouldn't need spacers with the 315 I think?
Old 01-30-2020, 08:59 PM   #28
Crushed 1LE
Got it. Thanks Mate! I'm looking to buy PS4's for these rims so I'll investigate the 315s.
