Old 10-23-2020, 08:24 PM   #15
Ajs16400
Drives: 2017 Camaro SS Convertible
Looks like 12677003 is different between the lt1 and lt4 as well. The fuel rails show the same part number for the lt1 and the lt4
Ajs16400 is offline   Reply With Quote
Old 10-26-2020, 02:31 PM   #16
laynlo15
Drives: 2022 Lt1 A10
I changed them out at least 6 times, I have a drawer full in my tool box. I would not hesitate to do that cause if you do have a leak on a one time use your screwed. Lt1 is 2200 psi and Lt4 is 2900. Don't be a fool and not change them.
Old 10-26-2020, 02:56 PM   #17
Ajs16400
Which fuel pipe comes with the magnuson 2300 kit when adding the supercharger?
Old 10-26-2020, 08:53 PM   #18
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Agree 100%. A fuel leak in that location and at that pressure...well, at least you’d be getting a new car. LMAO
Old 10-26-2020, 09:47 PM   #19
laynlo15
Aj not pipes come with the kit so you can just buy those from GM. They are about 75.00 buck for the pair. My dealer kept them in stock, maybe I'm the reason why. Haha
Old 10-26-2020, 10:03 PM   #20
Ajs16400
Accordng to the magnuson 2300 instructions it comes with the attached picture is this not the case anymore. Or is it better to replace that line with the lt4 line that attaches in the same location.
Old 06-10-2021, 08:57 PM   #21
C7George
Drives: 2016 corvette
We tried re-using them and ended up having a leak and had to replace them. That is how my luck works.
How did you know they were leaking?
C7George is offline   Reply With Quote
Old 06-11-2021, 06:06 PM   #22
s346k
s346k's Avatar
Drives: like an old lady
after seeing how the lines actually crimp on the ball end, i think you'd be a fool not to use new ones.
