Old 01-15-2020, 03:58 PM   #15
GM Lifer
GM Lifer's Avatar
Drives: 2016 Camaro SS in Red Hot
Originally Posted by Rock-It Man View Post
Chattering or snapping is bad, but I guarantee you that moaning when the diff is cold is just a feature of the limited slip design.
Change the fluid but eventually the moan will come back.
I'm starting to get the feeling you're right.
GM Lifer is offline   Reply With Quote
Old 01-15-2020, 04:18 PM   #16
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Don't worry, be happy. The moan is described as a normal condition in the Mustang Owners Manuals. Wish GM would do the same and put these complaints to rest.
I experienced a REAL differential catastrophe in a rental Jeep in Costa Rica. They had apparently put conventional gear oil in a LSD. When backing up, the bind and release sounded like I had just backed into a telephone pole.
If the moan only happens when cold, that means you have good LSD clutch grip when warmed up.
Old 01-15-2020, 07:31 PM   #17
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
I realize the limited slip fluid you are buying has the friction modifier in it. Buy the small tube of the limited slip friction modifier available at most auto supplies, add it and your groan is gone.
lt4camaro is offline   Reply With Quote
Old 01-16-2020, 08:19 AM   #18
GM Lifer
GM Lifer's Avatar
Thanks!
Old 01-16-2020, 08:20 AM   #19
GM Lifer
GM Lifer's Avatar
I had to do that very thing on a 2001 Corvette I once owned.
