Old 01-03-2020, 10:19 AM   #15
greg0ry
greg0ry's Avatar
Drives: 2019 Camaro SS 1LE
Originally Posted by LT4Greg View Post
Yeah gregory it used to be LT1 Greg when I owned the 2016 SS but when I bought my ZL1 I changed it to LT4 Greg!��
I hope to one day follow your footsteps, my man...
greg0ry is offline   Reply With Quote
Old 01-03-2020, 10:26 AM   #16
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Michelins are good, Continental Extreme Contact Sport tires are good, and other major brands. Get on Tire Rack.com and check the tires they offer for your SS or even Discount Tires website. I know this may sound crazy to some folks here but I may go back with the GYs when I replace mine! After all that’s the tire that the engineers set the suspension for on the ZL1s! They don’t have a good treadwear rating(220) as they are a performance rated tire.
Old 01-03-2020, 10:45 AM   #17
Yanbags
Yanbags's Avatar
Drives: '17 SS 1LE
Michelin Pilot Sport 4S will probably be the best street summer tire you can get and will last longer than the OEMs. They also have a better tread pattern for wet driving, but - (a) you live in LA, and I can't imagine you're worried about a ton of rain/wet driving, and (b) very wide and slim profile tires like these generally do not have the same tread depth to handle dispersing a lot of water. So when you drive in the rain, just dial it down a bit.
That being said, your tires still look completely fine to me. The edges just show typical wear of a tire seeing high loads closer to the sidewall. Have you looked at the treadwear indicators along the center of the tire? I drive mine basically to the cords for track use
Yanbags is offline   Reply With Quote
Old 01-03-2020, 10:59 AM   #18
metros11
Drives: 2018 SS 1LE
I would be a little concerned that the fronts are wearing quicker than the rear, it's typically the other way around.
metros11 is offline   Reply With Quote
Old 01-03-2020, 11:07 AM   #19
Mov Ov3r
What speed limit?
Mov Ov3r's Avatar
Drives: 2017 SS 1LE
Originally Posted by greg0ry View Post
Hey guys!!!! What's the best tire that's gonna give me wayyyyy longer life, I don't know.. maybe in the early 20k mile range.. but still good for performance?! Like I mentioned, I don't track! I just hit the canyons once in a while and have some random fun on the street (no burnouts). I'm looking at those Michelin Pilot Sport 4s. Ya'll think I can get around 20k out of those the way I drive??
I'm not sure you'll ever see 20K unless you go all season or buy stock SS rims with A/S, or go square set up. I am running Nitto NT555 G2's because that's what was on the car when I bought it, so far they are okay, but no traction in wet conditions under throttle. In dry conditions they are decent tires, a decent amount of grip (nothing compared to the GY)
Mov Ov3r is offline   Reply With Quote
Old 01-03-2020, 11:13 AM   #20
Martinjlm
Retired fr GM + SP Global
Martinjlm's Avatar
Seems to me that the fronts are wearing more close to the edge because of turning. I would suggest getting a tire depth gauge and measuring all your tires in the center.
Old 01-03-2020, 11:23 AM   #21
c4racer
Drives: 2016 SS Convertible
yup - that tire will easily do 20K, maybe 25K or the Pilot Super Sport.
c4racer is offline   Reply With Quote
Old 01-03-2020, 11:38 AM   #22
Laststandard
Drives: 2018 1SS 1LE
One thing to note, tread depth on the outer shoulder of the SC3 is shallow compared to the rest of the tire, so that area isn't always a good indicator that the tire is worn out.
These cars are pretty hard on the front tires. Replaced my fronts at about 8500 miles, kept the rears on as they still had life left in 'em.
2018 1SS 1LE (sold)
Laststandard is offline   Reply With Quote
Old 01-03-2020, 11:51 AM   #23
2019ZL1Droptop
2019ZL1Droptop's Avatar
Drives: 2019 ZL1
This is a link to Michelin tires here in Canada. Most of them have a 50000KM warranty which is about 31000 miles. Have a look and then dial up the USA Michelin site to help you make a decision.
Hope this helps out a bit.
https://www.michelin.ca/en/high-performance-tires-2/
2019 ZL1 M10 Convertible
Shadow Gray Metallic
SIGPIC][/SIGPIC]]
2019ZL1Droptop is offline   Reply With Quote
Old 01-03-2020, 01:53 PM   #24
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
People that don't track don't understand these things.
Old 01-03-2020, 03:02 PM   #25
Emoto
Sure, why not?
Emoto's Avatar
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon
This right here.
Measure your tread depth. It is something one should do routinely, anyway.
Example of a random tire tread depth gauge: https://shop.advanceautoparts.com/p/...4-8/11935569-p
Here is a decent write-up on measuring tread depth: https://www.tireamerica.com/resource/tire-tread-depth
Emoto is offline   Reply With Quote
Old 01-03-2020, 10:05 PM   #26
LESS1
Drives: Chevy Camaro
Looks to me like you may have overinflated the fronts based on the wear in the middle compared to the outsides. As someone else previously mentioned, the SC3s are thinner on the outside edges compared to the middle of the tire. In my case, I track my car a lot so the fronts lasted a little more than 3k miles before the edges gave up and began to cord. I am currently running `2.5deg negative camber up front, which is about as much as you can go without modification. As for replacement tires, if you plan to track your car I'd go with the OEM GY's, they are good tires, that can be sourced for a good price, and do hold up reasonably well given the low treadwear rating. Just my .02 so take it for what it's worth.
LESS1 is offline   Reply With Quote
Old 01-03-2020, 10:52 PM   #27
DannyC
Drives: 17 Camaro SS
I'm having tire issues also. But they seem to be just the opposite as Greg0ry. I have Continentals and they have no traction on a WOT launch. Is there any tires out there that would give decent traction and some long term durability??
DannyC is offline   Reply With Quote
Old 01-04-2020, 05:53 PM   #28
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Change them...
Firehawk Indy 500 are solid tires for the money.
