Old 12-28-2019, 04:24 PM   #15
Dixie ZL1
NOXQCES ZL1
Drives: 2017 Camaro ZL1
Originally Posted by cirpower View Post
Awesome work, you wonder why no one came up with this idea before and there is not a plug and play kit available. Please keep us posted if the pump helps the issue. cheers!
Thanks. Eager to get it installed.
Dixie ZL1 is offline   Reply With Quote
Old 01-11-2020, 02:06 PM   #16
Dixie ZL1
NOXQCES ZL1
Update - installed pump today and it appears to play nice with the FPCM during normal driving conditions. I’m going to keep the stock tune in it for a while to wring it out before putting the E85 setup back on it.
I’ll post an update after I understand what level of E it will support and put it back on the dyno.
Old 01-12-2020, 01:11 PM   #17
cirpower
Drives: Camaro ZL1
awesome, thanks for keeping us in the loop!
cirpower is offline   Reply With Quote
Old 01-12-2020, 03:54 PM   #18
Dixie ZL1
NOXQCES ZL1
Couple WOT pulls today and no issue with the FPCM. All seems good. Excited to get the Flex setup back on it.
Old 01-15-2020, 04:43 PM   #19
cirpower
Drives: Camaro ZL1
Great news, hopefully it works as intended!
Old 01-21-2020, 10:24 PM   #20
UFDUB
Drives: Chevrolet Camaro ZL1 1LE
Keep us updated. Exciting find
UFDUB is offline   Reply With Quote
Old 01-21-2020, 10:55 PM   #21
Dixie ZL1
NOXQCES ZL1
All good so far. At E53 with solid high & low side pressure. No issue with the FPCM with 93 or E so far. The car runs great at E50 and based on traction is making more power than ever.
I’ll be out of town for a week but hope to log E60 tomorrow before I go. I will move to E70 if E60 looks good and then on to full E85. I’ll dyno at the threshold of street tuning because I didn’t see the low side issue on the dyno.
My obvious goal is to see solid pressure at E85 so I don’t have to monitor E%.
So far so good.
Old 01-22-2020, 08:04 PM   #22
cirpower
Drives: Camaro ZL1
awesome news, really raises the question who will offer a kit!
Old 01-23-2020, 06:31 AM   #23
Dixie ZL1
NOXQCES ZL1
Let’s ensure it works with data and then I’ll provide all the part numbers for a DIY. It’s a pretty easy modification, but maybe someone will build assemblies.
Old 01-23-2020, 01:33 PM   #24
cirpower
Drives: Camaro ZL1
Sounds great, thanks!!!
Old 01-24-2020, 08:04 AM   #25
Choda
Drives: Turbo 6.2
Did you change anything in the tune? This is a huge success.
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100
Choda is offline   Reply With Quote
Old 01-24-2020, 11:30 AM   #26
Dixie ZL1
NOXQCES ZL1
Didn’t change anything in the tune. The pump works without issue on stock or E85 tune. No codes or issues of any kind.
Old 01-24-2020, 11:35 AM   #27
Dixie ZL1
NOXQCES ZL1
Unfortunately the full value of the DW400 pump won’t be realized in this project. The lowside was solid at E60, but the high side lost almost 2K PSI WOT @ 5800 RPM in 4th gear. I don’t have plans for a cam change, so I’m staying at around E40.
Really wanted to see performance above E70, but it won’t happen with my car. I can build another one for someone who has a larger cam lobe or high side pump if anyone wants to take the project from here.
Old 01-24-2020, 12:31 PM   #28
cirpower
Drives: Camaro ZL1
Oh no, so basically what you are saying is that without going with a cam, adding the upgraded fuel pump does not seem worth it? You ran E40 before the change, correct?
