#15 |
![]() Drives: 2015 Corvette Stingray Join Date: May 2019
BTW, our Adapters for 95 mm TB to MSD 103 mm are done. Perfect match from TB outlet to MSD inlet. Edge to edge all around, smooth blends, zero pressure drops, catches the seal completely without interrupting the flow.
Link to product here: https://www.solerengineering.com/sto...5-mm-to-103-mm and a couple of pictures: |
#16 |
![]() Drives: 17 Camaro SS Join Date: Nov 2019
I'm planning on the same setup but I ordered an A/F gauge to make sure it didn't lean out on upper rpms. I ported a lower intake on a V6 Dodge Magnum and it went way lean after 4000 rpm.
I had a tuner so fixed the problem before it caused any damage. I also have a tuner for my SS and will be watching A/F very close. Mike said the adapter would be done the end of this week so I guess they are. Probably order the TB in the next day or 2. |
#17 |
Thanks, DannyC.
Yes, all Adapter Kits are in stock, 95-87 (Stock), 95-103 (MSD), and 95-Custom (Just let us know the Manifold snout internal diameter). Adapters are included in the price of our 95mm (100mm Effective) TB's. Let us know which manifold you have so we can send the right one. Thanks, |
#18 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS/RS Join Date: Dec 2009
What’s the Bullnose for Mike?
Orange Krush II
#19 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro SS 1LE Join Date: Aug 2018
Probably seems like a stupid question and an obvious yes but it never hurts to ask lol. I already have a 95mm TB and unfortunately am not currently looking to upgrade my TB to one of your units at the moment.
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler. 2018 Colorado zr2 - zr2 sport bar, showcase spare tire. 2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace. 2017 Corvette Grandsport (sold) - untouched. 2006 GTO (sold) - iat relocation, air box mod, monero side marker lights. |
#20 |
See 103mm Manifold pic below. It has material protruding into the bore at 4x places to allow for screw holes. The seal also runs inwards there.
The bull-noses catch the Seal there, and allows flow to smoothly go over those protrusions. The Adapter outlet matches the Manifold inlet edge to edge all around. |
#21 | |
Thanks, |
#22 | |
![]() Drives: 2017 Camaro SS Join Date: Dec 2017
#23 |
looks like quality work.
#24 |
![]() Drives: 2018 1SS 1LE M6 Join Date: Jul 2013
So I'm very interested in this set up too, I got a rotofab Cai and looking to get the Soler LT5 throttle body with the adapter and the MSD IM but I've seen alot of mixed things about the MSD that it's not worth it, that you lose alot of low end power and only gain power up top? If u tune it can u still keep that low end power cause for a street car I feel like that low end torque will be alot more useful. How have ur cars reacted to this setup?
#25 | |
| Tags |
| msd atomic airforce, soler performance |
