Old 11-26-2019, 01:47 AM   #15
NowaChevyGuy
NowaChevyGuy's Avatar
Drives: 2016 Camaro LT1 RS Black on Black
Originally Posted by cellsafemode View Post
manual or auto?
with the auto, i'd be concerned about traction ...was eyeing up SS auto rears ...since it would be the same gear ratio, built to handle much more hp than the v6, so no chance of breaking and it's practically drop-in (with axles)
though, i suppose you can always wait and see and go lsd later.
I dropped the rear diff from a 2017 2.0 turbo manual trans in my RS. They are 3.23's instead of 2.77s, limited slip and the axles are way beefier then the v6 axles. It's a direct swap as well.
Do you know if the SC is CA smog legal?
NowAChevyGuy
2016 RS - Trifecta Tuned, 3.23 diff swap, Borla S Type, JMS Throttle Controller, Lambo doors, Monster stereo, GM LED rear tail lights, BMR swaybars/End Links/Trailing Arms, tinted dark and murdered out.[/br]
Car kicks ass! $20k.. and I get 20mpg with my foot in it, everywhere I go!.... Say somethin about V6's now...
NowaChevyGuy is offline   Reply With Quote
Old 11-26-2019, 07:47 AM   #16
Jason@Phastek
Jason@Phastek's Avatar
Drives: 2010 Camaro
Send a message via AIM to Jason@Phastek
Yes the Edelbrock 15995 is CARB legal. We have shipped several to California.
Jason@Phastek is offline   Reply With Quote
Old 11-26-2019, 07:48 AM   #17
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
I'd be looking to avoid changing the gear ratio to not have lower cruising mpg and I assume Edelbrock locks their tune like everyone else so you would have to have them custom the one they give you.... If they allow that.
Old 11-26-2019, 07:58 AM   #18
If you customize the tune, there goes your CARB certification.
Old 11-26-2019, 08:54 AM   #19
cellsafemode
indeed. all the more reason to just use the SS auto rear rather than the lt manual if you want/need lsd.
Old 11-26-2019, 03:37 PM   #20
SoulCyphyr71
Drives: 2018 Chevrolet Camaro RS
Nevermind, I just read your earlier post. Lol.
SoulCyphyr71 is offline   Reply With Quote
Old 12-02-2019, 01:18 PM   #21
cellsafemode
i opted against getting it. 10% off wasn't enough to justify dropping 4500 to make the car faster.
Though, I might also be bitter for having to drop a bunch of money on a new HMI because the existing one stopped working correctly.
Old 12-02-2019, 06:03 PM   #22
SoulCyphyr71
I also held off. Waiting to read Dgriff14's review of the SC. Instead purchased the 80mm throttle body and ported intake manifold from Overkill along with his tune during BF. I'll most likely hold off until spring and try to find a reputable installer.
Old 12-02-2019, 07:26 PM   #23
dgriff14
waddupdgriff
dgriff14's Avatar
Drives: Supercharged 2016 2LT RS
Yeah sorry for being so quiet. But I installed the SC the weekend before last but my car hasn’t run since. I uploaded their tune and now my car displays code P16F3 and the gas pedal is non-responsive.
They didn’t work Thurs or Fri so my car hasn’t be able to drive since I uploaded the tune. But when I upload my factory tune the gas pedal works fine.
dgriff14 is offline   Reply With Quote
Old 12-02-2019, 07:43 PM   #24
SoulCyphyr71
You are not the only person this has happened to. But the other was installing a ProCharger tune. Here's to hoping you get this rectified promptly. I'd have my hair pulled out by now.
Old 12-02-2019, 08:06 PM   #25
SoulCyphyr71
This is the link: https://www.camaro6.com/forums/showthread.php?t=565356
His error code was P1400, saying it was a cold start issue.
Old 12-02-2019, 08:16 PM   #26
SoulCyphyr71
So not quite the same, but he did have a dead pedal as well.
Old 12-02-2019, 08:26 PM   #27
dgriff14
waddupdgriff
dgriff14's Avatar
What the actual hell. And I’m running out of hair to pull out with each passing day. I’ve sent data logs, and the code seems to be an ECM issue. I just don’t know what to do since I’m not a Tuner and I’m basically at their mercy.
Old 12-03-2019, 04:08 PM   #28
cellsafemode
did you program the TCM ? googling shows that's a TCM error code. Flashing the tcm should have followed flashing the ecu.
Unless you have a manual.
3.6l, babeh, mooo, powah, supercharger
