#15 |
![]() ![]() ![]() Drives: 2016 Camaro 2SS Join Date: Apr 2018
Yea hate to say it but this one is going to fall on you. Your drivetrain warranty got shot out the window as soon as the Magnuson went on. I'd be surprised if Magnuson warrantied it either because I believe they require you to have a completely stock kit and your signature says you have a Rotofab added.
#16 |
Dyno Show Queen LOL
A few ways to get the bolt out... Since your on your own!
sharp ass punch and hammer punching a corner counter clockwise til you can grab with vise grips (room makes it hard in this situation) a dremmel tool with a thin cutting disc to cut a slice in it so you can back it out with a screw driver, may grind into the other metal "aluminum" should not be a problem unless u get carried away and go deep! bracket will cover the scar most likely! weld a small 1/4 20 bolt tip to the bolt and just back it out (got be able to weld like me of course) preferred method but harder.. use an Angle drill with a good bit like stainless or titanium, sharp hardened center punch, get the hole dead in the center so drill doesn't move around, and ease out extractor bit.. 1st 2 should work easiest provided they didn't use locktite.. seeing how it back out then broke i doubt they did.
#17 |
![]() Drives: 2019 ZL1 Crush Join Date: Jan 2019
To add on the above.
Angle drill with an extractor set drill bit. They are reverse cut and I find that slow even pressure with just the drill bit will usually get the stuck bolt out.
2019 Crush A10
E-Force 2650 670WHP 615WTQ All besides the 2650 is bone stock down to the air filter. |
