Old 11-09-2019, 01:47 AM   #15
Artood2s
Drives: Camaro SS 1LE
Originally Posted by TrackClub View Post
I think it is about $80-100? If they quote ya $300+ it would be a full "service" which is not needed. Cheers!
Thanks
Originally Posted by Whitespeed View Post
Rattling from the dual mode exhaust valves was quite common and the Bora Atak uses those valves. They are inside the tail pipe, so you won't see anything loose externally, but if you look down the outer tailpipes, you will see the valve inside. That's where I'd start looking.
Nigel
I thought the same, and pulled the fuse. Noise is still there. The squeak when going over speed bumps also makes it difficult to think it’s the valves.
Artood2s is offline   Reply With Quote
Old 11-09-2019, 03:51 AM   #16
MakCamaro
Makis
MakCamaro's Avatar
Drives: 2020 Red Hot ZL1 A10
The squeak is a different thing than the rattling noise and it relates to the brakes. IIRC there is a TSB for that. In other words you are talking about two different things here - and I also have both of them!
Old 11-09-2019, 04:05 PM   #17
Artood2s
Is the brake squeak at all times or only going over speed bumps? Thank you for pointing this out!!!
Old 11-10-2019, 05:08 AM   #18
MakCamaro
Makis
MakCamaro's Avatar
I hear the squeak when I brake, when the windows are open. But where I live there is plenty of speed bumps, so I always brake before going over them, lol! I think the squeak is completely related to the brakes. At least that’s what I’ve been told.
Old 11-10-2019, 10:23 AM   #19
ssmofo
ssmofo's Avatar
Drives: Chevy Camaro
Check the license plate, thats what mine was.
ssmofo is offline   Reply With Quote
Old 11-10-2019, 10:36 AM   #20
MakCamaro
Makis
MakCamaro's Avatar
This is what I also thought. Will check mine as well to verify that this is where the rattle comes from.
Old 11-10-2019, 06:35 PM   #21
Camarentino
Camarentino's Avatar
Drives: 2018 Camaro 1SS 1LE
I have the same squeak/ rattle since forever. I even gutted the entire rear seat section and decklid section but no luck. I even dynamated a few areas too. I'll gut the trunk next. Only other thing I noticed is the differential coolant lines have some play in the mounting brackets. That actually may be the source cause I hear it with the windows down as if it's coming from the outside.
2018 Camaro 1SS 1LE w/PDR Summit White
KN intake-MBRP cb- 2nd cat deletes- ACS sides- iroc Z spoiler- Eibach Pro- Katech 95TB- MSD Manifold-GM strut bar- Custom tune by Arun Ahuja @ CCPERF.ca
Camarentino is offline   Reply With Quote
Old 11-10-2019, 06:38 PM   #22
MakCamaro
Makis
MakCamaro's Avatar
And I thought it was just my car...
