Old 03-12-2022, 09:21 AM   #15
CamaroGen6
CamaroGen6's Avatar
Drives: 2020 Camaro 2SS
Originally Posted by bulldog385128 View Post
What size coupler did you get to make it work? I have the overkill 80mm throttle body as well, but I'm considering switching over from the cold air inductions v6 intake to the ss one.
I also have the v6 cai from cold inductions, but haven't added the throttle body yet. Have been wondering which route to take, convert to the ss cai + the throttle body or stick with the v6 version + throttle body. Either way, have you found out which coupler to use for the ss cai from cold inductions? Also, which coupler fits the v6 version?
2020 Camaro 2SS
CamaroGen6 is offline   Reply With Quote
Old 06-15-2024, 10:30 PM   #16
CZV
Drives: 2018 6th gen Camaro rs 3.6 v6
Hey so I installed my ss intake and I also have an 80mm TB and ported intake manifold , the thing is now my car doesn’t start up, it cranks and dies within 2-3 seconds. I still haven’t gotten my tune adjusted could that be why?
CZV is offline   Reply With Quote
Old 06-17-2024, 11:06 AM   #17
S.Macias
Monterey County Camaros
S.Macias's Avatar
Drives: Stock 2016 Camaro V6
I'd check the battery. With your intake and manifold the car would turn on but would have a very rough idle. On my 2016 I replaced the battery last year after it just suddenly stopped working. No indicator or anything. Radio and all that had enough power draw, but not enough to turn the car on
Instagram: @smaciasracing
S.Macias is offline   Reply With Quote
Old 10-04-2024, 11:57 PM   #18
phxsec
phxsec's Avatar
Drives: 2016 2LT A8
are you able to post a couple pictures of your set-up with the 80MM TB / SS CAI?
i'm generally curious on how i can set it up myself where it doesn't end up looking catawampus. thanks!
phxsec is offline   Reply With Quote
Old 10-05-2024, 05:25 PM   #19
ctrlz
I suspect vacuum leak.
