#15 | |
![]() Drives: gas powered Join Date: Jan 2019
#16 |
![]() Drives: '16 Red hot M6 Join Date: Apr 2014
My battery has been dropping to the 11s. I’ll drive it for a bit and it’ll be around 14 and then I turn it off and then back on and the battery goes back to 11s on start up. I do have air suspension hooked up to the battery so I thought maybe I made a mistake somewhere with the installation but i disconnected everything that’s not oem, even the dash cam and it’s still doing the same thing. At this point I’m thinking it’s the battery or the alternator. What’s my worst case scenario if the battery turns out to not be the problem? Just replace the alternator?
Follow me on Instagram
@julian_delgad0 |
#17 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Camaro 1LT Join Date: Jan 2016
dont forget to drop full charge voltage by 0.0144 volts for every 10 degrees F below 80
it is winter temps in many areas. |
#18 | |
![]() Drives: Chevy Camaro Join Date: Jul 2019
#19 |
![]() Drives: 2016 SS Join Date: Jan 2016
any one knows how the battery should be load tested? in the past autozone could connect directly to the battery, is that still required? as battery is now behind the panels in the back. or could the load test be perform under the hood?
#20 |
![]() Drives: Camaro 1SS A8 Vert Join Date: Sep 2018
Just get a new battery from Walmart , that way it is covered anywhere in the US.
Also a good battery tender. |
#21 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
Costco has Interstate AGM batteries. Direct replacement for the Camaro, including the vent hose connection.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers, Mamo Throttle Body Delivered: 08/15/2016 #TeamBeckyD Last edited by GroundhogSS; 10-29-2019 at 06:49 PM. |
#22 | |
Some of us,not everybody,a few,maybe a minority, try to determine if something is actually bad before running out and buying something new. Different way of looking at it.
#23 | |
There is a battery drain on Camaros and Vettes and the stock batteries are junk. If you keep going its going to burn up the starter. We spend thousands of dollars to make these cars look and run better. But cant drop $200.00 to keep it running correctly...... |
#24 |
This is the one I got and has the vent. Made by Johnson Controls/Optima..
https://www.walmart.com/ip/EverStart...up-H6/40647528 |
#25 |
![]() Drives: 2016 Camaro 2SS Convertible Join Date: Dec 2013
With no load, the battery voltage drop is negligible for that distance.
#26 | ||
I didnt think the starter amp draw was excessive nor the amp draw with the car off. But I am monitoring the system.
#27 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
Im going to buy a battery before it dies because of the complications with entering and exiting this car as well as accessing the battery in the event the battery does die just isn't worth it since everything is keyless (requires power)
I've got a 2017 with about 38k miles on it now, how soon should I replace it? |
#28 | |
![]() Drives: '16 2SS M6 Join Date: Aug 2019
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB '16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20) '14 Fusion Titanium 2.0T '83 Jeep Wagoneer |
