Old 01-05-2020, 02:24 PM   #15
kgf
kgf's Avatar
Originally Posted by grampa_ss View Post
Yep....You need to command the shift early, especially in 1st gear. At WOT, I command the shift at 33 mph, but it actually shifts at about I dunno 36-37mph not really sure, but the RPMs are around 6700-6800.
Use MPH to set your shift points, not RPMs. And command it before you actually want it to shift at. The shifting looks at MPH first. Example..you said you have your 2>3 shift at 60mph and 6200 rpms...and you saw it rev to 6700. that 6200 meant nothing.
Thanks, that all makes sense now that you explained it. Was worrying about the RPMs for nothing.
Makes me wonder why GM wouldn't program the manual mode like this from the factory. Seems like it would be better than forgetting you are in manual mode and not shifting. Seems like it would be easier on the motor.
kgf is offline   Reply With Quote
Old 01-05-2020, 03:14 PM   #16
grampa_ss
grampa_ss's Avatar
I agree. The stock setting bounce you off the limiter. Pretty dumb.
Old 01-06-2020, 09:43 AM   #17
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
Because it is an actual manual mode that way. You guys have turned it into max performance auto mode.
Old 11-15-2020, 04:25 AM   #18
Bangkok_ZL1
Flying around Thailand
Bangkok_ZL1's Avatar
Drives: 2019 Camaro ZL1
This is Beautiful. Especially since I'm a little older (forgetful). And my new 2019 has no warranty whatsoever from GM. I think I need to have a diligent listening ear with some of you to get advice what you would do all over again if you had a new ZL1 with no warranty.... I will say that the company I bought the ZL1 from is giving me a 1 year warranty on them. So I won't make too many obvious mods from the get go. But after a year when I know the car is solid. I want to bring in a few (hundred) more horses.
Bangkok_ZL1 is offline   Reply With Quote
Old 12-16-2020, 02:32 PM   #19
JSH
JSH's Avatar
Drives: '20 ZLE
Has anyone figured out how to make these TUTD edits to the T93 TCM?
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 12-16-2020, 03:16 PM   #20
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
That TCM is currently unsupported by HP Tuners, so no way to flash it until they do.
Old 07-01-2021, 07:42 PM   #21
jasonz28camaro
Drives: 2007.5 Duramax
Any of you do any tuning with the truck OS? I have TUTD working on my 68 but it won’t tapshift at WOT using this method or manually shifting, shifts immediately and fine at part throttle. The reason I mention the truck OS is because when I’m in L gear to access the TUTD mode (different from cars) hptuners says my driving mode is in “normal” mode, not TUTD. With mine being a swap project I could be an oddball, I’ll need to do some testing on my wife’s Tahoe to see what hptuners says for driving mode when I use her TUTD. Either way just wondering if anyone has successfully figured this out for trucks. I’ve checked some truck forums and such with no luck.
Built C6Z 600whp NA - SOLD
Built LSX 96SS - SOLD
68 Camaro - 6.2/10l80, self built and tuned.
jasonz28camaro is offline   Reply With Quote
Old 06-09-2022, 12:02 PM   #22
Red Lightening
Red Lightening's Avatar
Drives: 2016 SS Camaro Convertible
8l90 Manual Mode tuning, burnouts
Have you had any issues with burnouts? Mine is jumping from 2nd to 3rd, then "D" drive, then neutral all in just a couple of seconds or less, (on its own)? Impossible to do a proper burnout. Launches and shifts down the track well. I know its been a while since this post, but any thoughts?
Red Lightening is offline   Reply With Quote
Old 06-09-2022, 01:20 PM   #23
JSH
JSH's Avatar
Drives: '20 ZLE
We've solved the T87a/A10 (2020+) tuning issues and can launch in first or second gear, and it shifts at set shift points automatically while in Manual. The car is faster with 1st gear launch. I drive thru the box and burnout in 2nd at around 5k rpm. No jumping from gear to gear. All runs have been with nannies off, but I'm going to leave nannies on next trip.
2020 ZL1LE A10.
Old 06-10-2022, 07:52 AM   #24
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
No issues...The problem sounds like your foot is too heavy. You don't just floor it to do a burn out. If you are going to do a second gear burn out then you need to modulate the throttle to keep it under the commanded shift MPH.
Old 06-10-2022, 08:15 AM   #25
JSH
JSH's Avatar
Drives: '20 ZLE
Put in manual, pull up your HUD, give it a little throttle in 1st to start tires spinning, shift to 2nd, spin them for 3 or 4 seconds at ~5k, let off and roll forward.
2020 ZL1LE A10.
Old 06-10-2022, 02:42 PM   #26
KingLT1
KingLT1's Avatar
No you don't shift during a burnout with these transmissions. It's hard on them.
Old 06-10-2022, 02:52 PM   #27
ZL1Atlanta
ZL1Atlanta's Avatar
Drives: 2017 Chevrolet Camaro ZL1
It is fine if you shift at a lower RPM. It's when you take it up to 6K+ and then shift during a burnout that really beats on them. I start in second, take it up just enough to get the tires turning, and then go to third to finish the burnout. It takes WAY too long to get a proper burnout in second gear.
2017 ZL1 - PB 7.85 @ 175 MPH @ 3682 lbs @ 1313 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned
ZL1Atlanta is offline   Reply With Quote
Old 06-10-2022, 08:15 PM   #28
JSH
JSH's Avatar
Drives: '20 ZLE
Yea, I can see starting in 2nd and quickly shifting to 3rd.
2020 ZL1LE A10.
