#15 |
![]() Drives: 2016 Nightfall Metallic Grey 2ss Join Date: Oct 2017
Here are two screenshots of the knock when it happens.
#16 |
Just wanted to update this thread, I swapped back to stock rockers with smith brothers trunnion (btr's che's) and the knock is completely gone on a pull all the way to 140.
#17 |
Don't you think you should update your sale thread with these results? I know you want to sell these rockers, but it's kind of shady the way you are listing them if you know they cause issues don't ya think? If anything I would call TSP and tell them what you found instead of trying to pass them off on another member without letting them know ahead of time what they might run into.
#18 | |
#19 |
Right on...would never of expected somebody to run those rockers on a stock cam.
#20 |
#21 |
I don't believe it had anything to do with those rockers. Not enough of a ratio increase to add any substantial lift or duration at the valve.
#22 |
#23 | |
I then did TEA LS6 heads , Fast 92 intake, and a Comp cam that was designed around the SLP 1.85 rockers and it ran like a champ. Pulled all the way to 7200rpm with a little 224/228 .534 .537 112 @ 1.7 ratio cam.
#24 | |
| Tags |
| knock, lt1, rockers, roller rocker, texas speed |
