Old 10-21-2019, 04:37 AM   #15
The Specialist
The Specialist's Avatar
Drives: 2018 Summit White Camaro SS 1LE
Originally Posted by AD17SS1LE View Post
The skip shift sensor will force you to shift from 1st to 4th under light/moderate acceleration. You can get an aftermarket sensor that eliminates this feature. There is also a reverse lockout sensor as well. I suspect there may be an issue with your reverse lockout sensor. Here is a link to a thread for a member that may have installed the aftermarket skip shift sensor in the reverse lockout sensor. I like your work around of shutting down in reverse.
https://www.camaro6.com/forums/showthread.php?t=543926
What does a reverse lockout sensor do?
I tried again yesterday.
Car fully warmed up. From a dead stop I accelerated as lightly as possible holding the car under 20mph in 1st gear. No skip shift activation or light.
The Specialist is offline   Reply With Quote
Old 10-21-2019, 10:22 AM   #16
AD17SS1LE
AD17SS1LE's Avatar
Drives: 2017 Camaro SS 1LE
Reverse lockout sensor is a safety mechanism to keep you from shifting into reverse accidentally like if you are shifting into 5th and miss 5th and get reverse. When the sensor has 12 volts reverse is available, when no voltage you can't shift into reverse. I don't know what GM is using to trigger the 12v to the solenoid. I think you have an issue with your lockout sensor.
2017 Camaro SS 1LE
Pray ported TB/IM
TSP 1 7/8 Long tube headers w catted con pipes
Taylor plug wires
Mishimoto oil cooler
Elite X2 catch can
AD17SS1LE is offline   Reply With Quote
Old 10-22-2019, 04:23 AM   #17
The Specialist
If it is the lockout sensor, why am I only having the issue when the outside temperature is in the 40's or below at start up?
Does that lockout sensor have anything to do with the car no longer doing its low mph skip shift thing?
Old 10-22-2019, 07:39 AM   #18
AD17SS1LE
AD17SS1LE's Avatar
The lockout sensor has nothing to do with skip shift. I don't know why you only have the reverse issue when temps are below 40. I guess you can just continue to shut it down in reverse or try replacing your lockout sensor.
2017 Camaro SS 1LE
Pray ported TB/IM
Taylor plug wires
Elite X2 catch can
Old 10-22-2019, 08:01 PM   #19
Merc
In The Circle
Merc's Avatar
Originally Posted by MatthewAMEL View Post
Had intermittent hard shifts into reverse after a year with my OEM fluid. Never any issues with grinding.
I track my car so I change the tranny and diff fluid pretty regularly. I switched to Redline D4 last year and noticed improvement in my cold shifting vs OEM.
I still use OEM fluid in my diff.
I use Redline in my 2010 M6 and yes shifts better when it's cold for sure.
Old 10-23-2019, 04:59 AM   #20
The Specialist
I took her out yesterday at just under 50 degrees to go get an inspection. I had shut her down in reverse the last time I drove it. Backed out of my driveway and 1st was a little hard to get into. The inspection shop is only three miles away. After I arrived, I needed reverse and she wouldn't go the first time I tried. I had to go 1st-2nd-3rd. let out the clutch a bit and then go for reverse again. All the gears were a little tough. After I was done with the inspection I went for a ride for about ten or so miles. No issues after that. Every gear was like butter. I sat at a red light and played around with all the gears. This is why I'm led to believe it has to do with the fluid temperature. All summer there was absolutely no issues.
Old 10-23-2019, 05:17 AM   #21
The Specialist
You folks that have swapped out the fluid in your M6 6th Gen.
Is this true? I copied this from another forum. I'm not sure if they're talking about the 6th Gen or something else.
Is it really this much of a Cluster F to check and change out the fluid?
""" Use a pipe cleaner to check your fluid level. Bend the tip, and then dip it in the well while the car is on a level surface to make sure the fluid is even with the bottom of the fill plug.
It's very easy to get the old fluid out. Very hard to get the new fluid in. During my change, I had to have a helper send "gulps" of fluid down to me from inside the passenger compartment with a 3 foot long fill hose. (Fortunately, I had the center console out.) There isn't enough space beside the transmission to get a bottle upside down with a normal short fill hose. """""
Old 10-23-2019, 06:51 AM   #22
6spdhyperblue
Drives: 2SS 1LE
Doesn’t sound like a fluid issue. You Ever bleed your brakes ?
Seems more like a clutch problem
Old 10-23-2019, 08:01 AM   #23
The Specialist
The clutch fluid? I have heard about that going dirty and needing to be changed out. My Clutch itself should be good. I haven't even gone past 5K RPM yet. No burnouts, no clowning around power shifting. None of that stuff.
Old 10-23-2019, 03:53 PM   #24
AD17SS1LE
AD17SS1LE's Avatar
I used a pump to get the new fluid in. I also spoke to Tremec about fill 1/8" below fill hole, they said they never heard of that an recommended to fill until fluid was coming out of fill hole.
2017 Camaro SS 1LE
Pray ported TB/IM
Taylor plug wires
Elite X2 catch can
Old 10-24-2019, 01:11 AM   #25
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
GM says to fill until it comes out then remove 8oz. id go by Tremic though. maybe thats why we are having syncro problems.
Old 06-04-2020, 12:49 AM   #26
Plasar
Drives: 2017 ZL1 Vert M6
* Good trick of shutting off car in reverse.
* You could also park car facing out and start in first.
Plasar is offline   Reply With Quote
