Old 10-09-2019, 08:06 AM   #15
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
The hammertone on my BMR bars is holding up just fine.
Old 10-10-2019, 06:34 PM   #16
NickyRacerBoy
Drives: 1LE
Hammertone toe bars holding up too. Have already worn out hiem endlinks though!
NickyRacerBoy is offline   Reply With Quote
Old 10-10-2019, 06:37 PM   #17
NickyRacerBoy
Drives: 1LE
My post #5 was copy and paste quote from other member. Based on how car felt I am delighted!
Old 10-10-2019, 08:35 PM   #18
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
I put this in another thread: Nick, on your R7’s, you buying them heat cycled, or do you do the heat cycling and wait a week as recommended by Hoosier, or just hammer on stickers til they hear cycle out or cord? I’ve seen all of the above be proclaimed as “correct” with R7’s.
RUQWIKR is offline   Reply With Quote
Old 10-11-2019, 08:20 AM   #19
NickyRacerBoy
Drives: 1LE
So this last set really did seem to be more consistent!
I did 6 laps on them at the end of a track day and parked the car. Let them sit till next track day (~4 weeks)
I've been told from guys that are SCCA national champs that heat cycling them from Tire Rack doesn't work. Now maybe that because they dont offer that service or maybe there is truth to it.
Old 10-12-2019, 05:47 PM   #20
NickyRacerBoy
Drives: 1LE
Last set we're heat cycle by myself did six lapse then put the car in the trailer. I do have to say that these tires did seem to last a little bit longer for sure. The guys at Phoenix Racing told me that he'd cycling the Tire Rack isn't the same. Not sure why that would be
Old 10-13-2019, 07:33 AM   #21
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
Only thing I can think of is that Tire Rack's heat cycling does not combine temperature with repeated cornering, braking, and heavy acceleration loads the way driving on the track does. Basically temperature in a straight line at constant speed or with at most relatively gradual speed changes.
Tire Tech: Competition Tire Heat Cycling Service
(Lea en español)
Many tire manufacturers use very aggressive tread compounds for the Track & Competition DOT-legal tires they've developed for autocrossing, track days and road racing. And just like other high performance parts, these tires will provide more consistent performance and last longer if they are properly broken in.
The first time Track & Competition DOT tires go into service is very important. All tires deflect under load, and their tread rubber compounds repeatedly stretch and relax as they roll into and out of contact with the road. This stretching breaks some of the weaker bonds between the tread rubber molecules, generating heat. If new Track & Competition DOT tires are initially run too aggressively, too hot or too long, some of the stronger bonds will also be broken, which reduces tire grip and wear.
Putting new Track & Competition DOT tires through an easy initial heat cycle and then not running them for a minimum of 24 hours allows the rubber bonds to relink in a more uniform manner than they were originally manufactured. Heat cycling actually makes Track & Competition DOT tread compounds more consistent in strength and more resistant to losing their strength the next time they are used.
While it's important to heat cycle tires, how it's done isn't as important.
On the Track
Heat cycling can be done by installing tires on the car and running 10 to 15 minutes on a racetrack. Start with easy laps, and build up speed as the session continues. End up running 5-10 seconds off your normal pace and be careful not to spike the tire temperatures by spinning, sliding or locking the tires.
An important step in tire heat cycling is that after being brought up to temperature, the tires require a minimum of 24 hours to relax and relink the bonds between the rubber molecules. Drivers attempting to heat cycle tires in the morning for use a few hours later in the afternoon will not experience any benefits from the morning attempt at heat cycling. Heat cycling tires on Saturday means not using them again until the same time on Sunday.
By Tire Rack
Our heat cycling service begins by mounting the tire on an appropriate-width wheel and inflating it to the desired pressure. It is then placed in our heat cycling machine which has three rollers positioned at the corners of a triangle. The tread flexes where it comes into contact with each of the rollers, stretching the rubber compound enough to progressively bring it up to temperature all the way around the tire and across the tread. There is no artificial heat added by an oven, forced air or heat lamp.
The tread temperature is monitored with a pyrometer to confirm when the tire has reached the desired 170-180° F temperature. The tire is then dismounted and stamped as Tire Rack heat cycled. Since the minimum 24-hour waiting period typically occurs while the tires are in transit, the tires are ready to use when they arrive!
The only thing our heat cycling service doesn't do is scuff in the tires.
Choices
While both ways will get the job done, many driving enthusiasts have chosen Tire Rack's heat cycling service because it allows them to maximize their time on the track. They don't have to invest in extra sets of wheels to manage multiple sets of tires, nor dedicate early weekend sessions to heat cycling new tires for the following days.
We've compared tire heat cycling done on our test track and in our heat-cycling machine. Measuring the tread temperatures with a probe-style pyrometer has confirmed we can't quite duplicate the heat cycling machine's controlled process with tires mounted on a car. We found on-the-car heat cycling was challenged by different driveline configurations (front-wheel, rear-wheel or all-wheel drive), vehicle weight distributions and competition camber settings that made it difficult to generate even tire temperatures on front and rear axle positions, as well as across the entire tread. Our heat-cycling machine allowed us to achieve appropriate and more consistent temperatures across the tire's tread without causing treadwear.
https://www.tirerack.com/tires/tiret....jsp?techid=66
Norm
Old 10-14-2019, 08:36 AM   #22
TheRealJA105
Drives: 2013 C6Z06
You don't have the BMR front bar, but I just blew out my 3rd bushing on the front passenger side. Does your Hotchkins front bar use the very wide bushings like the factory bars do? Or are they the narrow "autozone" ones that BMR provides?
Old 10-14-2019, 09:57 PM   #23
NickyRacerBoy
Drives: 1LE
Norm
True...yeah no side loads
Old 10-14-2019, 09:59 PM   #24
NickyRacerBoy
Drives: 1LE
Tomorrow I'll have car on the lift and compair stock versus Hotchkis.
Old 10-15-2019, 08:20 AM   #25
Choda
Drives: Turbo 6.2
do you guys cruise around in the 1st or 2nd hole then switch to the 3rd on race days?
2016 Twin Turbo Camaro SS - 968hp/970tq 8.9@153
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100
Choda is offline   Reply With Quote
Old 10-15-2019, 10:29 AM   #26
TheRealJA105
Drives: 2013 C6Z06
I run the BMR bars on middle hole front and full stiff rear all the time.
Old 10-15-2019, 12:02 PM   #27
Norm Peterson
Different car, but I can't be bothered changing bar stiffnesses, too much work for no real benefit. Don't see the point in making the midcorner handling balance for street driving different from its track day balance by changing only one bar.
Norm
Old 10-15-2019, 03:07 PM   #28
ony1265
Drives: '17 Krypton 1LE
I have the Hotchkis FSB, it uses OEM like bushings. It threw off my ride height until I got BMR endlinks, but no issues with it other than that. Need to pickup a RSB to tune out some of the push I still have.
ony1265 is offline   Reply With Quote
