Old 10-15-2019, 12:11 PM   #15
Matos1LE
Drives: SS 1LE
Originally Posted by JLz06 View Post
I think it may also have more to do with the cooler temps on that day vs the day the SS1LE was tested. ZL1 1LE has considerably more aggressive tires that need heat to perform well. Also, being setup with the stiffest setting for the shocks wouldn't help it with that track being as bumpy as it is. I would have to think if you took a ZL1 1LE with just a LT1 instead of an LT4 in it, on a track like PBIR or Homestead, it should still be a bit faster than a SS1LE.
When they mentioned that bit about the stiffest setting for the shocks, I was confused. I don't think you can stiffen the DSSV shocks on the ZL1 1LE, all you can do is change the camber. They're not a traditional coilover with adjustment knobs.
Matos1LE is offline   Reply With Quote
Old 10-17-2019, 02:23 PM   #16
FH212
FH212's Avatar
Drives: 2015 Camaro Z/28
Still amazed at how great the 6th Gen Camaro is.
2015 Camaro Z/28 - Red Hot
1978 Trans Am Y88 Special Edition 400/4 speed
2001 Mecham Trans Am #3 - 7.0L LS1
FH212 is offline   Reply With Quote
Old 10-17-2019, 03:46 PM   #17
Wyzz Kydd
Drives: 2018 Camaro SS1 1LE
Yep. I've driven some pretty decent performance cars and the way the 1LE handles surpasses them all.
Wyzz Kydd is offline   Reply With Quote
