Old 09-22-2019, 10:51 AM   #15
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
good numbers but I would of expected the power to carry out further then that.
Old 09-22-2019, 01:21 PM   #16
laynlo15
Drives: 2022 Lt1 A10
I'm just running mine out to 6800. Are you running the LT4 HPFP and injectors?
Old 09-22-2019, 07:31 PM   #17
shinysun
Drives: 2016 Camaro SS
Yap. I am just wondering about the limitation of the injection window.
No sign of bad things with that, but seems it is almost the boundary as it is over 6ms.
shinysun is offline   Reply With Quote
Old 09-22-2019, 07:34 PM   #18
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I would not do over 6ms in my humble opinion... How do your low side fuel pressure and high pressure rail numbers look?
Old 09-22-2019, 07:49 PM   #19
shinysun
Yap, I also try not to. The rail numbers are quite stick with the desired , I think it is thanks to BAP so far.
I believe if I shot the meth and adjust the lamda, can reduce the injection time.
Old 09-22-2019, 08:07 PM   #20
Joshinator99
Moderator
Time to add Port Injection and spin that 2650 up!
Old 09-22-2019, 09:40 PM   #21
Drsagacity
Drsagacity's Avatar
Not sure I understand the infatuation with port injection when the 2650 hasn’t touched the end of fuel. Swap to e85 and this car is close to 1000whp.
Look at the recent posts about the port injection on the “other non-Maggie 2650”. Running port injection, with alky, with back seats pulled and running Cxx race fuel...the 2650 beat the 2300 Maggie time by what, .001s?
Seems to me the 2650 has a lot of room to go before anything like that makes any sense.
Then again, maybe I am thinking about this all wrong.
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 09-22-2019, 10:26 PM   #22
ramairroughneck
Drives: 2018 Camaro SS
I know you must be talking about 6GenMikes 416ci 2300R on E85/meth that just ran 9.0. Who is running port injection on an Edelbrock 2650 that is .001 faster? I only know of Talley. He runs c16/meth to get by with his LT4 fueling. No port injection. I think the mention of PFI is just to be able to see what the Maggie can do. It’s not a knock. Most every twin turbo or big Procharger runs it. Now that these bigger blowers are out it seems logical to run it to get the most out of them just the same. I could see the Maggie 2650 making some serious power when that upgrade comes out. Cordes is already making a thousand with aftermarket DI using the 2650R. I’m sure they will be surpassing the LT5s with PFI.
ramairroughneck is offline   Reply With Quote
Old 09-22-2019, 11:16 PM   #23
toohighpsi
Drives: 2015 C7 Z06 M7
6gen Mike is running the lingenfelter injectors - they are monsters so he can get by with E85 on the DI, his fuel limit will be the HP pump.
He's also pretty much at the limit of his 2300R, switching to a 2650R will probably net him another 100 RWHP with no other changes. I don't think we'll have to guess at this one, we'll probably find out pretty soon.
Old 09-23-2019, 05:47 AM   #24
laynlo15
I think we will.
Old 09-23-2019, 03:50 PM   #25
SienarSystems
SienarSystems's Avatar
Drives: ZL1 1LE
I’m willing to be the test case for the NW 112, big gulp and all the Lingenfelter fuel goodies...
SienarSystems is offline   Reply With Quote
Old 09-24-2019, 11:07 AM   #26
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
It sounds like the stock short block may not be though, HAHAHA.
Any word yet on your set-up?
'20 ZL1 Black "Fury"
radz28 is online now   Reply With Quote
Old 09-24-2019, 08:15 PM   #27
shinysun
As it approaches 900~1000 rwhp, I am concerning on head bolts. I am using ARP stud kit, but wondering if I need any other extra works?
Old 09-24-2019, 09:55 PM   #28
laynlo15
What mods are done the motor? That's a lot of rwhp.
