Old 09-16-2019, 10:01 PM   #15
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
Originally Posted by jwaked View Post
Getting back to the mods scene after 10 years with a 18 SS MT. First on my mods list is a Procharger Stage 2 Tunner kit with all the LT4 Fuel things. Goal is a street toy, some 1/4 passes, 600-650RWHP stock block but down the road Cam, heads, etc.
What are these and what are your recommendations:
1. Upgrade Head Unit, P1X or D1SC?
P1X for SBE, D1SC if you plan on doing rods and pistons
2. 8 or 10 inch rip belt?
8 rib belt is fine
3. ATI balancer?
not really needed
4. Intercooler, standard or race
stage 2. standard is stupid small. race requires removal of driver aux radiator
5. Bypass valve, Standard, bullet or race?
race
6. gear set, standard or quiet?
helical is standard iirc... you usually have to ask for straight cut gears. but helical anyways, unless you want it to be really loud.
Sorry for so many questions, I am a bit rusty and would like to do it right the first time.
Thanks
Jay
answers
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
Old 09-17-2019, 03:21 AM   #16
NickeyMatt1LE
Drives: 2017 Camaro SS 1LE
D1sc is still the best street centrifugal blower for 600-800 rwhp. Makes the most midrange and still has more up top than the p1x. The x blowers are more suited for the coyote's with the extended rev range they have.
NickeyMatt1LE is offline   Reply With Quote
Old 09-17-2019, 09:13 AM   #17
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
very cool info. Thanks everyone. Some things are still a bit fuzzy, like why would anyone buy a P1X if the D1SC is only $50 more, and I doubt is because of the $50. What advantage does the P1X have over the D1SC?
I believe it's a little lighter...I would still opt for the D1sc if you plan on upping the power down the road. It future proofs you a little better imo.
Old 09-17-2019, 09:24 AM   #18
DorkMissile
DorkMissile's Avatar
Drives: DZ
Or just buy the ECS kit, which comes with all the good parts standard. Only two options to consider, a 1200cfm blower vs a 1750cfm blower and do you want satin or black finish.
Bigger I/C than the Stage 2 PC, comes with a belt setup that has more belt wrap & grip with a standard width belt, comes standard with a good BOV, doesn't require changing the lower pulley or using an adapter on the factory crank pulley.
DorkMissile is offline   Reply With Quote
Old 09-17-2019, 12:26 PM   #19
jwaked
jwaked's Avatar
Drives: 11 Corvette ZR1
Is this the Stage 2 intercooler recomended? The options are standard 750 IC or Race 1200 HP.
Chevy Camaro SS LT1 2016-2019 Procharger Supercharger - Stage II Intercooled Tuner Kit
https://treperformance.com/i-2389976...tuner-kit.html
11 Corvette ZR1
18 Lexus GX460
19 Yamaha FX Cruiser SVHO
jwaked is offline   Reply With Quote
Old 09-17-2019, 12:50 PM   #20
Juiced1
Drives: 2012 2SS CAMARO 45th
I would recommend the stage 2 intercooled kit, P1X blower, ATI balancer and the 8 rib set up. This will give you some room to grow but will also handle any further mods.
Juiced1 is offline   Reply With Quote
Old 09-17-2019, 01:05 PM   #21
jwaked
jwaked's Avatar
Why P1X? everyone is leaning towards the D1SC at least to have room to grow in the furure. What is the advantage of the P1X over the D1SC? if its a little less down low it might not be a bad thing since I have a manual tranny.
Thanks
11 Corvette ZR1
18 Lexus GX460
Old 09-17-2019, 04:22 PM   #22
Dysan911
Dysan911's Avatar
Drives: 2017 50th Anniversary 2SS
Thanks
J~, I commend you on asking all these question before you buy and fully wanting to know all the pro's and con's. Honestly I would go with the D1SC. I can't see you having a single regret with that one.
Dysan911 is offline   Reply With Quote
Old 09-17-2019, 04:31 PM   #23
jwaked
jwaked's Avatar
Totally agree with you, most likely thats the one. same benefits as the P1X but way more room to play and grow. Thanks man.
Jay
11 Corvette ZR1
18 Lexus GX460
