Old 09-07-2019, 03:48 PM   #15
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
Made tiny video to show you.
https://youtu.be/bEG4mNquaw0
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 09-07-2019, 03:50 PM   #16
Living_Quiet
Drives: 2010
Originally Posted by LT4Greg View Post
Sh*tbox cars? WTF, Living Quiet?
Between the A8 transmission shudder that has plagued GM engines, and the AC that apparently requires a dissertation for maintenance and operation, what would you label them?
At the very least they clearly can't handle any humidity.
Living_Quiet is offline   Reply With Quote
Old 09-07-2019, 03:55 PM   #17
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
You need to stay on the 5th gen forum page! I used to own a 2010 SS but wouldn’t get on the 5th gen forum and bad mouth them! The 5th gens had their share of issues and problems too.
Old 09-07-2019, 04:39 PM   #18
Aragorn
Drives: Camaro SS 1LE
Originally Posted by Living_Quiet View Post
WTF?
This reads like a full freaking manual on how to baby your AC if you actually want to use it.
My 2010 Camaro's AC ran perfectly for 10 years with no smell, didn't matter what I did or didn't do- it just worked.. WTF is GM doing to these cars?
Sorry if this reads harsh but this is unacceptable in 2016-2020 cars.
Negative—I’ve had other cars/brands with evaporators that also get musty.
Aragorn is offline   Reply With Quote
Old 09-07-2019, 04:50 PM   #19
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
Clearly they cant handle the humidity? I didn't see 100 posts on 2016+ cars smelling bad. Where are you getting this info from?
I live in humidtyVille in south FL, were its 97% almost everyday. I had a 17 and now a 18 with no issues with smell like the OP describes. I too owned a 2010 and 2013, they weren't perfect either...
Old 09-07-2019, 04:56 PM   #20
LT4Greg
LT4Greg's Avatar
He doesn't know what he’s talking about and doesn’t even own a 6gen Camaro! Enough said!
Old 09-07-2019, 07:44 PM   #21
Living_Quiet
Drives: 2010
lmfao who said I didn't own one? I simply said the 2010 I had didn't have these problems. Don't jump too conclusions champ.
It's just sad to see some of you in here taking on the role of apologist in place of GM for their shortcomings. But that's exactly why they continue get away with churning out this type of quality.
Old 09-07-2019, 07:47 PM   #22
LT4Greg
LT4Greg's Avatar
Whatever Champ!
Old 09-07-2019, 08:59 PM   #23
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
If you run on recirculated air there should be very little moisture on the evaporator core as the recirculated air should have way less humidity and moisture than the 90% humidity outside air in the summer. If you run the system on "fresh" air from outside, the evaporator will collect tons of moisture as it removes the humidity from the outside air, saturating the evap core and box.
None of my cars ever stunk from the A/C system in +40 years of driving.
OP
Try a new cabin filter, see if you can find one with carbon for odor control. Then see about getting your evaporator disinfected.
Our shop does this treatment, seems to work pretty good.
'18 1SS 1LE Black, PDR
Old 09-07-2019, 09:58 PM   #24
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
Look at my past posts, even from 2010, LOL
I am in no way a chevy FAN BOY, I call a spade a spade!
At times, I think I'm their biggest critic.
