09-04-2019, 06:17 PM | #15 |
Drives: 1LE Join Date: Sep 2017
09-04-2019, 07:00 PM | #16 |
Love the car and the videos
09-04-2019, 07:13 PM | #17 |
09-04-2019, 07:45 PM | #18 |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
Great wheeling!!! Yeah!!! Given you stay in high rpm so often id suggest you consider swapping valve springs at least once per season. Just a suggestion based on my circle track buddies who swap them for every race. Just as a precaution. Cheers and thx for posting!
09-04-2019, 08:43 PM | #19 | |
Yeah I will this winter. I get oil analyzed every drop. I change oil every 4 hours of run time. 15/50 Mobil 1. I log oil psi thru AIM DL plus I look at the Cosworth "vehicle health" too. Never below 30 psi. High is 72. Since inboard toe rod bolt was loose I will take car to get aligned again...what should I run for rear tow? Last outing I ran R7 315 30 18 F and their new 315 40 18 R. The R is tall, 27.2" so the car has more rake then it normally would have. Is that something that I would notice? I run that tall tire because 5th gear totally suck! I will send trans out to RPM tran to have 5th changes to ZR1 5th gear which is .84 I believe. Tighter will make for smoother shifting too as synchros wont spin so hard. |
09-04-2019, 08:54 PM | #20 |
Drives: 2018 Torch Red SS 1LE with Whipple Join Date: Jul 2018
What's your rev limiter set to? Sounds higher pitched than I would have thought? I don't have perfect pitch or anything, just my initial reaction in hearing you row through the gears. Sounds great regardless!
09-04-2019, 09:16 PM | #21 |
09-05-2019, 08:38 AM | #22 | |
Long answer: it is all about balance, which consists of several things working is unison: Entry - rake, toe and brake bias all play a role. Mid corner - first 2 Exit - first 2 Generally speaking: More rake - faster rotation on entry. Too much rake will make the car lose. Less rake always means more stability and faster top speed at the expense of rotation on entry and mid corner. More rear toe - more stability. Too little toe will make the car lose and often times very lose! More front brake bias - more stability. Too much front bias will make the car push in entry. Too much rear bias will make it lose on entry. Having said all that, all these settings work TOGETHER so when changing something it is important to do it one at a time based on how the car feels NOW and then test to see how a change affects the overall balance. Cheers! |
09-05-2019, 10:03 AM | #23 | |
Rake on car is a lot like sport bikes then. Lower the fork tubes up in the triple clamps will make bike turn in faster but will be nervous at high speeds... Now obviously there is no comparison made for tow! LOL Trackclub I did notices was that understeer was more controllable with throttle then before. Not sure if he newly added areo or the the 40 series |
09-05-2019, 07:38 PM | #24 | |
09-05-2019, 07:53 PM | #25 | |
One of the Phoenix boys drove my car and said its way to soft. Need springs or stiffer bars. Watching ASA vid my car does need to be flatter. |
09-06-2019, 09:14 PM | #26 | |
Keep in mind our suspension is a pretty capable and well matched package. Stiffer is not always faster, either. NASCAR Cup cars were set up very soft to max mechanical grip for the Glen race. Just an fyi. And that's crew chiefs that are real pros...Stiffer will change weight transition rates (introducing different handling) and may potentially have a big effect on tire wear. Not saying dont try it, but do it with a real and specific purpose regarding intended handling. When i went with bigger Pfaff bars on my Vette, i oblitarated my outside front tire in a day for no change in pace. Having said that, given your car has aero now, stiffer might be better. Just keep in mind the shocks are calibrated to springs...so... |
09-06-2019, 10:09 PM | #27 | |
09-07-2019, 08:04 AM | #28 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
You were also off your normal line through T1, due to the lateness of an inside pass. I'm guessing that you hurried your steering input up a bit as well. What I'm getting at is to find more reasons about why your car might be too soft; don't recalibrate in an effort to help just a single off-line situation. Nice lap time. Norm
'19 WRX 6M (the family sedan . . . seriously) |
