Old 09-07-2019, 07:15 AM   #15
wnta1ss
Drives: 2017 Camaro 1SS
Did you also do the LT4 MAP at the same time?
Question, why did you use the LT4 MAP instead of the LS9 MAP? Doesn't the LT4 MAP have different wiring connections than the LT1 MAP? Whereas the LS9 MAP takes the same plug as the LT1.
Old 09-07-2019, 08:59 AM   #16
JANNETTYRACING
JANNETTYRACING's Avatar
With a Procharger the LS9 LSA Map sensor works best.
The LT4 TMAP has temp sensor in it so we reserve that for the PD blowers so the computer can see actual IAT.
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 09-07-2019, 01:03 PM   #17
oldman
Drives: SS 6 speed of course
Thanks Ted, yea the red map I guess mine was from a LS9......
Old 09-09-2019, 12:06 PM   #18
bonestock
Drives: 17 camaro ss
my Procharger came today, Time to break some knuckles....
bonestock is offline   Reply With Quote
Old 09-09-2019, 12:09 PM   #19
bonestock
where in Texas are you? There is a tuner in Cedar Park (Austin), a good one in Corpus, a few others.
dallas, we got good tuners here, but its all about that $$$
Old 09-21-2019, 05:31 PM   #20
bonestock
I have everything all installed with no vacuum leaks, the car threw like 4 codes, one was a fuel pump code, and the others were ecu, not reading right. drove around, and codes went away. Now my car is shutting down when i stop, is it learning? Im calling procharger monday
Old 09-21-2019, 08:57 PM   #21
Dysan911
Dysan911's Avatar
Drives: 2017 50th Anniversary 2SS
Are you using the procharger canned tune?
Dysan911 is offline   Reply With Quote
Old 09-22-2019, 12:16 PM   #22
bonestock
can tune
Old 09-22-2019, 01:49 PM   #23
Dysan911
Dysan911's Avatar
Let’s start with doubling checking the maf harness extension is plugged in good and secure on both ends. I’d even go as far as looking at the male to female pins and make double certain none are bent or shorter than the others.
Old 09-22-2019, 11:24 PM   #24
bonestock
that fixed it. Who makes a transbrake or do i gotta jerry rig a 2 step?
