Old 08-27-2019, 10:54 AM   #15
Cannon Green
Drives: 2018 Camaro 1SS
Originally Posted by LT4Greg View Post
Yeah really and don’t let the tank get so low that you do run out! Those 6.2 liters have a good appetite for gasoline! You didn’t damage your Camaro either! ��
Thank you
Cannon Green is offline   Reply With Quote
Old 08-27-2019, 12:58 PM   #16
95 imp
Dumb Ass Deluxe
Originally Posted by beedo View Post
Fuel flowing THROUGH the pump cools it, it doesn't have to to be submerged in fuel.
You have a fuel pump that circulates gasoline over the motor windings and the armature bearings?
Old 08-27-2019, 02:34 PM   #17
ssmofo
ssmofo's Avatar
Drives: Chevy Camaro
I can't believe I wasted 7 minutes reading this bullshit.
ssmofo is offline   Reply With Quote
Old 08-27-2019, 03:37 PM   #18
GearheadSS
GearheadSS's Avatar
Drives: 23 LT1/86 IROC-Z
Originally Posted by 95 imp View Post
FYI.... Running your car below 1/4 tank continuously is a great way to burn out the pump. The fuel in the tank keeps the pump cool.
Old 08-28-2019, 10:18 AM   #19
ctrlz
Biggest danger of running all the gas out is sucking up sediment into the pickup screen and whatever other filter they have integrated into the pump. Typically NOT a problem in a car that is so new.
It is generally considered beneficial for the longevity of a fuel pump to keep it submerged in fuel, which acts as a heatsink. This does not take much gas. This is mainly a problem for those maniacs out there who like driving around with less than 1/8 tank and the fuel light always on.
https://www.autoserviceprofessional....desktop-view=1
Old 08-28-2019, 11:35 AM   #20
kevint
Drives: 2013 1SS
Originally Posted by GTSLOW View Post
I'm guessing this is an old wives tale that never died.
Besides, there are much more important things to worry about: the biggest being what brand of cover to use when storing the car inside overnight.
kevint is offline   Reply With Quote
Old 08-28-2019, 12:47 PM   #21
95 imp
Dumb Ass Deluxe
Originally Posted by ctrlz View Post
"The most common cause of fuel pump failure is frequently running the tank low on fuel, which causes the motor to overheat. The second most common cause is fuel contamination, usually dirt and rust particles that clog the fuel strainer and prevent the pump from drawing enough fuel under high engine load. If enough contamination gets past the pump’s intake strainer, it can actually jam the pump and stop the engine immediately."
Evidently, you're an idiot and so is the moran who wrote the article....
Old 08-28-2019, 04:49 PM   #22
Cannon Green
Not on our car bud do your research this is a Camaro forum not a dumb ass deluxe forum
Old 08-28-2019, 06:47 PM   #23
Need4Camaro
Drives: '17 Camaro 2SS & '99 Camaro Z28
I have to admit that when I switched to shorter commutes, I can go almost 2 weeks between fill ups but the weakness is you develop a habit of just jumping in and driving and forgetting to fill up because you almost never need to.... I came real close to running out of fuel once and ran dangerously low on a few occasions. The Heads Up Display I feel contributed to this because you begin checking the gauge cluster less often.
Need4Camaro is offline   Reply With Quote
Old 08-28-2019, 07:31 PM   #24
95 imp
Dumb Ass Deluxe
After reading your last two posts, it sounds like I fit in perfectly right here
Old 08-28-2019, 09:34 PM   #25
Whocares05050
Drives: 2018 Camaro SS 1LE
Good news and I got a oil change at 500 miles and 1500 so should be like no sediment
What the hell does an oil change have to do with sediment in your gas tank? 🤣🤣🤣
Whocares05050 is offline   Reply With Quote
Old 08-29-2019, 12:39 AM   #26
beedo
Drives: 18 2SS 1LE NFG
beedo is offline   Reply With Quote
Old 08-29-2019, 10:56 AM   #27
RobbyBeefcake87
RobbyBeefcake87's Avatar
This happened to me recently, car got really low and I felt like not didn't quite pull as hard for a little bit after I put in gas. I used to run it low after every fill but now I try not to let it get lower than a 1/4 or 1/8 if I can help it. Im sure its not the worst thing ever here and there, but better safe than sorry.
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler.
2018 Colorado zr2 - zr2 sport bar, showcase spare tire.
2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace.
2017 Corvette Grandsport (sold) - untouched.
2006 GTO (sold) - iat relocation, air box mod, monero side marker lights.
RobbyBeefcake87 is offline   Reply With Quote
Old 08-29-2019, 11:38 AM   #28
ctrlz
well, it's "moron," and may be the case.
I think what they are getting at is repeated low volume fueling allows the pump to run hotter and increases the risk of failure. I don't see how you could go wrong with that logic. Certainly brushes failing due to overheating is true of any motor.
