Old 09-01-2019, 12:56 PM   #15
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Drives: 2018 ZL1 1LE
There’s another, albeit more expensive,but not plastic, player: https://cordesperformanceracing.com/...xpansion-tank/
Old 09-05-2019, 04:07 PM   #16
bobfic
bobfic's Avatar
Drives: 2019 ZL1
For those that purchased the kit after last update that instructions would be included, how did that go....but the main question is have you seen any improvement after install? Thanks
bobfic is offline   Reply With Quote
Old 09-12-2019, 06:34 PM   #17
PROMETHEUS
PROMETHEUS's Avatar
Got my kit today and installed it in about 2 hours. I know...…..longer than it is suppose to be, but I wanted to make sure I didn't screw anything up. Instructions were adequate, but could use some improvement...….IMHO.
If I could make one suggestion "which I think had already been made by another thread, it is alot easier if you remove the OEM Airbox, before you get started. If gives you so much more room to work. Not required.....but highly recommended!
Old 09-13-2019, 05:17 AM   #18
ADM PERFORMANCE
Drives: Anything I want
If I could make one suggestion "which I think had already been made by another thread, it is alot easier to remove the OEM Airbox, before you get started. If gives you so much more room to work. Not required.....but highly recommended!
Good idea.We can add that to the very first step.
ADM PERFORMANCE is offline   Reply With Quote
Old 09-13-2019, 06:42 AM   #19
bobfic
bobfic's Avatar
Drives: 2019 ZL1
Thanks for update..report back if any changes in throttle response..
Old 09-13-2019, 07:16 AM   #20
PROMETHEUS
PROMETHEUS's Avatar
Havent take the car out as of yet!
Old 09-13-2019, 07:20 AM   #21
IneedAZ
IneedAZ's Avatar
I did mine last month and it feels better since doing it. It definitely felt down on power prior to the install. My car is 2.5 years old with 11,400 miles on it.
Old 09-13-2019, 11:35 AM   #22
AZ_SS
AZ_SS's Avatar
Drives: 2018 Camaro ZL1 M6
Thats the one I'm running.
AZ_SS is offline   Reply With Quote
Old 09-13-2019, 12:00 PM   #23
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
How'd the install go? Does it come complete with hoses, clamps, instructions etc...?
Old 09-13-2019, 01:31 PM   #24
AZ_SS
AZ_SS's Avatar
I was down there at the shop, so I let them install it but it does come with everything you need. There are other members on here who are not local to Cordes and have installed them themselves. It appears very easy.
Old 09-13-2019, 03:16 PM   #25
Lugojf
Lugojf's Avatar
Drives: 2017 Camaro ZL1
Easy install!
Lugojf is offline   Reply With Quote
Old 09-16-2019, 07:13 AM   #26
PROMETHEUS
PROMETHEUS's Avatar
I was wondering why a small rectangle portion on the side of my tank had a brushed look to it. I thought maybe it was just in the manufacturing, but appears they sanded off the "Edelbrock" name.
Old 09-16-2019, 08:25 AM   #27
IneedAZ
IneedAZ's Avatar
For those running the ADM, since it sits over the exhaust you may want to do like i did in adding some Hi-Temp hose cover over the bottom hose and put a piece of cut DEI heat material on the bottom of the tank. Figured it couldn't hurt to take the extra steps in trying to keep it cool.
Old 09-17-2019, 03:55 PM   #28
PROMETHEUS
PROMETHEUS's Avatar
I purchased mine a couple of weeks ago and a couple of days ago discovered the "one and done" clamp that attached the hose to the upper flange was leaking a very small amount fluid from the bottom. Don't know if it was defective/not tightened/wrong size. When I went to take it off, I literally pulled it off by hand. Replaced it with a worm gear clamp.....all good.
