Old 08-13-2019, 09:43 AM   #15
laynlo15
Drives: 2022 Lt1 A10
Thanks 10.
Old 08-13-2019, 09:48 AM   #16
drfeelgood
drfeelgood's Avatar
Drives: 2017 ZL1 Convertible A10
Check out Magnuson's Facebook as Mike talks about the 2650 that he put on his C7 Z06. I believe he made 740s or so and the motor is bone stock except for lower pulley and that was on 13 to 15 lbs of boost on 91 octane. It might even be in our FI section also. Magnuson vs Ebrocks 2650.
Thanks
'17 White ZL1 A10 Convertible - TM ported TB - RotoFab CAI - 2.3" griptech upper pulley - Kooks 1 7/8" Headers with High Flow Cats - Borla S-type Catback - Audio Overhaul - NavTV M650-GM - 20" BlackDiForza- Michelin Pilot Sport4S - Tuned at BRC Raceworks (606rwhp/675trq)
'14 CTS-V Coupe - ZL1 lid - Ported TB - Ported Snout - AirRad CAI - 8.66" lower - 2.55" upper- Greenbelt - SW Headers - SW Catback - Varimax Intercooler Pump - Track Attack Intercooler-Tuned at BRC Raceworks (551rwhp/516trq)
'17 Maserati Levante- STOCK
drfeelgood is offline   Reply With Quote
Old 08-13-2019, 10:23 AM   #17
F419sr1
F419sr1's Avatar
Drives: 2017 ZL1
Originally Posted by drfeelgood View Post
Quick question for the gearheads... with the following supporting mods:
2.3" upper
RF intake
ported TM throttle body
1 7/8" headers with high flow cats and full catback
What would be my expected WHP gain by simply upgrading the SC to the whipple 2300? Is there even a benefit of doing this upgrade if I'm tuned on 91 octane?
Magnuson Makes the blower they are talking about. A larger blower can spin slower making the same boost. producing less heat along with larger bricks for cooling. I have a whipple and making the same hp I was with a ported blower and meth. No more methanol
Kooks full exhaust, Roto Fab, Whipple,Williams 103, Fore innovation, JRE cam and tuning
F419sr1 is offline   Reply With Quote
Old 08-13-2019, 02:22 PM   #18
drfeelgood
drfeelgood's Avatar
Gotcha, thank you...
ben debating on whether it would be worth it to upgrade the blower to a Whipple of Magnuson ... I don't want to run E85 or add meth, so looking for maximum results while still being able to use our crappy 91 octane in California
Old 08-15-2019, 11:18 PM   #19
XXX ZL1
XXX ZL1's Avatar
Drives: 2024 ZL1 M6
How the install coming along?
2024 Riverside Blue ZL1 M6
Magnuson 2650R, NW 103, Roto Fab Big Gulp
Kooks 2 inch LT's, Stainless Works Legend NPP
THP Billet Valve Covers, Mighty Mouse Wild CC
Signature Forged 20x10.5/20x11.5, BMR springs,
BMR Cradle lockout, AAD Billet arms
2023 Vivid Orange ZL1 M6 - sold
2019 Riverside Blue ZL1 A10 - sold
XXX ZL1 is offline   Reply With Quote
Old 08-16-2019, 07:08 AM   #20
7LitreC5
Drives: 18 Tahoe RST, 19 Z06
I haven't had time to work on it since last weekend. I'll be back at it this afternoon. Unfortunately, I only have 2 or 3 hours a week to work on it.
7LitreC5 is offline   Reply With Quote
Old 08-16-2019, 07:29 AM   #21
laynlo15
You'll get there.
Old 08-16-2019, 10:12 AM   #22
staples87
Drives: 2017 Camaro ZL1
I'm curious as to what fuel pressure is going to look like? Running a bigger blower is going to require more fuel in itself, then adding flex fuel to the mix is going to put even more of a strain on the stock fuel system.
What are the 2300s able to make with a NW103 and pure 93 octane before pressure starts dropping and the car starts running lean?
'17 Camaro ZL1 M6
staples87 is offline   Reply With Quote
Old 08-16-2019, 10:26 AM   #23
F419sr1
F419sr1's Avatar
Drives: 2017 ZL1
Shouldn’t change a lot at the same boost levels. It should run cooler AITs so it shouldn’t pull timing.
Old 08-16-2019, 01:30 PM   #24
7LitreC5
The good news/bad news for me is that I live at over 7000 ft altitude. This means that in reality, even with the 2300, my actual horsepower will be way under what you'd see at sea level. Here -20% (or more) loss in power is normal.
The 2300 with the provided 80mm pulley will put my boost near stock levels. If my fuel is ok, I have a 70mm pulley that I can install in the future.
Old 08-17-2019, 11:19 AM   #25
XXX ZL1
XXX ZL1's Avatar
Drives: 2024 ZL1 M6
Spare time is hard to come by for sure. Lol. I just sold my ported stock unit and doing 2300 also. Watching yours come together gets me motivated to wrench on mine.
Old 08-17-2019, 11:45 AM   #26
laynlo15
Going from the 80 to 70 should be about 3 to 4 lbs of boost. Every 5mm of pulley change is generally 1.5 to 2 psi more boost.
Old 08-17-2019, 03:15 PM   #27
7LitreC5
I think that I read that the 70mm pulley is good for 16ish psi which would give me 13ish at my altitude.
I have a question. On my 2300, there is what looks like an IAT sensor screwed into the passenger side runner on the front. There is no reference to it in the instructions. I assume that I just ignore it?
Old 08-17-2019, 11:54 PM   #28
TMS
TMS's Avatar
Drives: 2018 ZL1 1LE - HBM, PDR
You won’t use it. I pulled mine and plugged it.
JRE Tuned (HPTuners) | 15% OD (9.17" crank pulley) | TVS2300 Maggie Heartbeat Supercharger - 14 psi | E-50 (DSX Flex Fuel kit) | JMS FuelMax Fuel Pump Booster | LPE Big Bore High Volume DI fuel pump | LPE High Flow DI fuel injectors | LT5 95mm TB | RotoFab CAI | AEM X-Series OBD2 wide band gauge | Elite Engineering E2-X catch can | Borla S-type NPP Cat-Back 3" exhaust | Forgeline GTD1 5-lug Satin Graphite | SunTek wrap | C-Quartz Finest Reserve ceramic coated
TMS is offline   Reply With Quote
