Old 08-08-2019, 12:15 AM   #15
Aragorn
Drives: Camaro SS 1LE
12k miles. Rattle from left vent.
Aragorn is offline   Reply With Quote
Old 08-08-2019, 12:21 AM   #16
Frank237
Frank237's Avatar
Drives: Kubota 2640, 83 BMW R-65, 2017 1 SS
2017 1SS, A8.
23,000 miles, zero issues. NO squeaks, rattles or shudders.
Frank237 is offline   Reply With Quote
Old 08-08-2019, 12:40 AM   #17
enzia35
Drives: '16 Garnet Red 1SS
Originally Posted by protovack View Post
which ones do you have? Have you been able to isolate and fix any?
I have a bunch too
I have a rattle in the headliner when it's cold. Seat squeaks when I lean back in the seat, some rattle in the front driver side dash. Pushing on the bits doesn't stop the rattle so it's inside the dash.
'16 Camaro 1SS
'18 Miata GT
Old 08-08-2019, 02:31 AM   #18
Clearly_Canadian
Clearly_Canadian's Avatar
Drives: 2017 2SS Camaro
Originally Posted by geaux_tigerss View Post
Wear and tear is fine, but interior rattles seem to be multiplying exponentially.
I thought I was the only one. I’ve only had it a couple months and it seems like every week there is a new squeak, rattle or clunk.
2017 Camaro 2SS, K&N Air, Borla S-Type, Cat Delete, 1LE replicas, Hotchkis Swaybars, Eibach Springs. ALL BMR arms, end links, chassis braces and cradle lockout. Hurst shifter.
Clearly_Canadian is offline   Reply With Quote
Old 08-08-2019, 06:47 AM   #19
mrgoodbytes
mrgoodbytes's Avatar
Drives: '18 2SS/EU (+Recaros) M6 Red Hot
This thread was an awesome idea. Usually you only hear about the problems. Heck, I check the forum daily just to read about new problems.
Mine has 1 year of use, only in the summer, and 8000 miles. Other than a few wrinkles in the leather on the side bolsters of my driver side recarro seat, no wear or tear inside the cabin. I avoid the highway whenever possible, to minimize risk of stone chips.
Only problem so far is a tiny leak from the serpentine belt tensioner, (which I believe is due to a poor design). So far it is working fine, but will be replaced never the less.
mrgoodbytes is offline   Reply With Quote
Old 08-08-2019, 08:51 AM   #20
Gadsden
Drives: 2019 Camaro 1SS, 2017 Silverado LTZ
I've racked up about 2800 miles on mine in only 6 weeks. So far the only concern is my dry a$$ elbow makes a white mark on the door panel at the top.
Gadsden is offline   Reply With Quote
Old 08-08-2019, 09:09 AM   #21
s346k
s346k's Avatar
Drives: like an old lady
12k miles. no issues yet.
Old 08-08-2019, 09:26 AM   #22
L8Apex
Drives: 2016 2SS
21k miles, lower part of the leather seat bolsters are starting to show wrinkles.
The only other thing, and it's a 2016 that I bought it as a CPO in March, is the rocker panel area in
front of the rear wheels. Hard to believe the amount of sand blasting it seems to have received.
This area should have been fully covered in film at the factory, the piece that is there, is way to small
L8Apex is offline   Reply With Quote
Old 08-08-2019, 09:34 AM   #23
grampa_ss
grampa_ss's Avatar
44,000 miles. no squeaks, rattles or shudder. Everything still works great. A few rock chips here 'n there.
Old 08-08-2019, 04:59 PM   #24
geaux_tigerss
geaux_tigerss's Avatar
Drives: 2019 GMC Sierra 1500 AT4
I have a bunch too
One in the dash, one somewhere in the back, and one that comes and goes in the driver's side door.
My 2017 was a rattle trap as well. Hell, it's probably my fault.
I haven't even tried to find them, let alone fix them. Most of the time I'm riding with the windows down, the NPP valves open, and the radio kicking. Don't notice them then...
Summit White
6" Lift, 37x13.50R24's
geaux_tigerss is offline   Reply With Quote
Old 08-08-2019, 05:28 PM   #25
Mgsouthwest2001
Mgsouthwest2001's Avatar
Drives: 18 Camaro 2SS 8A Hyper Blue
The paint on mine has held up well in the 10 months I have owned the car. Still looks fantastic! I have had to fix just a few small rock chips with some Dr. Colorchip. I installed the front and rear ZL1 rock guards after I first bought the car and I feel they have saved me some chips for sure. The paint has been every bit as good as the paint was on my past Challengers and better than the paint on past Mustangs I have owned. I have no problems with the interior whatsoever. No annoying rattles, early seat wear etc. Mechanically, I have unfortunately had the dreaded 8A shudder as well as the rear diff groan on cold turns. GM did fluid changes for both (had the latest flush on the tranny) and both problems are gone at least for now. Fingers crossed those problems stay gone. It is a fun and silly fast car for sure.
18 Camaro 2SS: Hyper Blue 8A
Mgsouthwest2001 is offline   Reply With Quote
Old 08-08-2019, 05:45 PM   #26
laynlo15
Drives: 2022 Lt1 A10
Great, 12700 miles, 225 drag strip passes, still on the same tranny, axles, rear diff. I did have to build a short block as the piston ring lands on number 1 and 8 didn't really like 16.5 of boost. Love it.
Old 08-08-2019, 09:43 PM   #27
ItsChristianInHD
ItsChristianInHD's Avatar
Drives: 2017 Camaro 2LT RS 3.6L
2 years.
21,000 miles.
Some leather areas needed replaced under warranty. (Console, seat cover, and driver head rest). Oh and the fifty emblem on the steering wheel got replaced for peeling and 2 rims got replaced for peeling.
Rock chips and a dent. The side rockers are pretty sand blasted if you look very close.
2 fluid flushes and a Torque converter later and shudder is gone.
Otherwise small stuff, car always starts (knock on wood) no issues will driving.
ItsChristianInHD is offline   Reply With Quote
Old 08-09-2019, 11:20 AM   #28
RoninSS
Drives: 2019 SS1LE Garnet Red../Silver CL30
3500 miles. Runs like a raped ape. Seats and dash are perfect. Small click sounding rattle in the back somewhere, my guess is the upper deck
RoninSS is offline   Reply With Quote
