Old 04-30-2020, 03:36 PM   #15
Mike@SolerPerformanceLLC
Mike@SolerPerformanceLLC's Avatar
Drives: 2015 Corvette Stingray
Glad to see your results. You are very welcome NA18. No idea where I got the B19 from.
Tiffany,
Soler Performance LLC,
support@solerengineering.com
www.solerengineering.com
(251) 468-9786
Mike@SolerPerformanceLLC is offline   Reply With Quote
Old 05-27-2020, 12:23 PM   #16
MrNoosNoos
Drives: 2019 Camaro 2SS 1LE
Originally Posted by NA18CamaroSS View Post
The car was re-tuned yesterday for the new mods. This car was base-lined bone stock July 31, 2019 at Superior Automotive's Dyno Jet and made 404 torque/403 WHP. Then we added a flex fuel kit and a Soler Performance throttle body and had the car tuned. The Camaro made 438 torque/434 WHP-(note it was going back into closed loop above 6,000 RPM in this dyno session-hence the power dip).
Since that dyno session in September of 2019, we added the following mods-Roto Fab CAI, Soler Performance 95 MM throttle body and Soler Performance 95 MM to 87 MM adapter, Pray Performance ported stock intake manifold, and New Era Performance cat delete pipes. Took the car to Church Automotive Testing in Wilmington, CA and had it retuned. It made 506 ft-lbs. of torque/492 WHP on the Dynapack dyno. If you are not familiar with the Dynapack, the dyno bolts directly to the hubs and eliminates the inertia of the wheel and tires, thus it reads higher than most Dyno Jets.
This morning we took the car back to Superior's Dyno Jet to see where the car is compared to where it was. The car made 468 ft-lbs of torque/464 WHP. In summary, with the modifications and the tune, the car gained 64 ft-lbs of torque and 61 WHP. About 30tq/30WHP can be attributed to switching to E85. That concludes this test. Heads/cam/headers on the drawing board for 2021.
Great numbers man! Are you still running stock headers? Any reason you went a smaller TB over a larger one?
MrNoosNoos is offline   Reply With Quote
Old 06-04-2020, 04:03 PM   #17
NA18CamaroSS
NA18CamaroSS's Avatar
Drives: 2018 Chevrolet Camaro 2SS 1LE 6M
Stock headers-yes. Running the 95 MM throttle body, so it's bigger than stock. Getting a ported MSD in the mail soon (Thanks Pray Performance! https://www.camaro6.com/forums/member.php?u=118563 ) , so the adapter plate will be going bye-bye.
Bolt-ons.
NA18CamaroSS is offline   Reply With Quote
Old 06-11-2020, 08:41 PM   #18
NA18CamaroSS
Update
We received the ported MSD from Pray this week. Installed it a couple of days ago. Based on several graphs showing the MSD vs the OEM manifold, we added a little bit of fuel above 5,000 RPM. No other changes were made to the tune. I did not bring my laptop to the dyno today and I regret it. The engine was running about 12.5: 1 through most of the RPM range(Green line on AF graph); I would have liked to have leaned it out to make the comparison more accurate. The previous tune with the Pray Ported OEM intake manifold was was running at about 13:1 down low gradually dropping to about 12.6:1 up top. (Red line on AF graph.) The comparison is about what is to be expected, a little loss of torque down low, about a 25 WHP gain at 6,500 RPM. The car went from 403 HP/404 Torque to 464 HP/468 Torque with a flex fuel sensor, E85, Roto-Fab CAI, Soler Performance 95 MM throttle body, Pray Performance ported OEM intake manifold, New Era Performance cat delete pipes, and a tune. Installing the Pray Performance ported MSD IM netted 473 HP/463 torque, untuned. We should pick up about 5 more WHP and 5-10 more ft-lbs of torque once the air fuel is dialed in. I attached a graph that Brett put up on Facebook where he does a direct comparison between his ported OEM intake manifold and his ported MSD intake manifold.
Bolt-ons.
Old 06-12-2020, 12:11 AM   #19
BDPhoto519
BDPhoto519's Avatar
Am I reading that right?
You gained about 9HP and lost 5tq at peak after buying a $1400 intake and paying to get it ported as well? I know the afr is slightly off 0.1ish up top, but thats not really anything and that doesn't make me super pumped to change my stock intake.
Hopefuly the re tune nets some better results for you!
2018 Camaro 2SS A8 Redline Edition
BDPhoto519 is offline   Reply With Quote
Old 06-13-2020, 01:20 PM   #20
LT1ornothing
Drives: 2020 LT1 M6
Intake manifold gains are minimal without ported heads and a cam swap. If you were to compare the gains on a heads and cam LT1 from stock LT1 intake manifold to a ported aftermarket intake manifold, you would see impressive results. Some naturally aspirated mods require complementary mods to show their true potential.
Old 06-13-2020, 09:27 PM   #21
NA18CamaroSS
The end game is to get ported heads and a bigger cam. The mods installed so far will only enhance the performance of the head/cam combination. Driving the car, I don't really feel the loss down low. When the tune is dialed in the losses below 5,000 RPM will be minimal. What can be felt now, is how hard the car pulls past 5,500 RPM. With the stock intake manifold, even though it was ported by Pray Performance, the car felt flat above 5,500 RPM. If I spent the $1,500.00 expecting 20+ peak WHP gain, I would have been disappointed. When the tune is dialed in with the current setup, the 30 WHP gain at 6,500 RPM will have been worth it, to me. I know that all of the current modifications will help the motor to take advantage of the head/cam package that I install next year.
Bolt-ons.
Old 06-14-2020, 07:52 AM   #22
s346k
s346k's Avatar
Drives: like an old lady
Dyno was a Dynojet. Ambient temp ~84 degrees F. Humidity ~ 50%. Correction factor SAE. Made 403 RWHP and 404 RWTQ on pass #2 and made 404 RWHP and 408 RWTQ on the third pass. First pass not recorded/printed...PCM was pulling between 3-5 degrees of timing due to knock retard...
i think it would also be fair to mention that the baseline dyno is low. 5* of timing is a lot, it also heavily depends on where it was pulling timing vs rpm.
Old 06-27-2020, 02:11 PM   #23
NA18CamaroSS
Tuned MSD
We took the car to the dyno this week and retuned the air/fuel for the MSD intake manifold. Gained most of the HP/Torque that we lost below 5,000 RPM. The OEM intake manifold is better at 4,000 RPM, but the MSD intake manifold is about the same everywhere else below 5,000 RPM. Above 5,000 is where the MSD shines when compared to the OEM intake manifold. We gained 33 HP and 26 Ft.-lbs of torque at 6,500 RPM. The MSD picked up about 15 HP peak over the OEM, and made slightly more peak torque.
Bolt-ons.
Old 01-31-2021, 12:20 AM   #24
Ademarco
Drives: 18 Ford Raptor, 21 2SS 1LE M6
Man, thanks for posting so it gives us an idea on future plans. I would like to stay NA if possible and get 450/450 on 91 pump or E85. Surprised you haven’t done headers yet.
Ademarco is offline   Reply With Quote
Old 01-31-2021, 01:17 AM   #25
NA18CamaroSS
Funny that you mentioned not doing headers yet-installed the ARH system yesterday. At 6,500 RPM this car sings now.
Bolt-ons.
Old 03-06-2021, 05:10 AM   #26
Essmotorsports
Essmotorsports's Avatar
Drives: Chevy Camaro 2018
For a test run did you ever dyno the MSD manifold and ported 95mm TB with the adaptor that necks down to 87mm? I'm curious how much this would affect power numbers.
Essmotorsports is offline   Reply With Quote
Old 03-06-2021, 06:27 AM   #27
NA18CamaroSS
No. Once I got the MSD, I eliminated the adapter. Never tested the MSD with the adapter installed.
Bolt-ons.
Old 03-06-2021, 06:48 AM   #28
Essmotorsports
Ok thanks for posting such good info tho! 👍
baseline, dyno
