#15 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
i had mine replaced at the dealership for free around 29k on my 16 1ss
#16 |
![]() Drives: 2016 Camaro 1SS Join Date: Aug 2016
My car is out of warranty, Anyone else change it? Just want to confirm you use the 15mm bolt on the tensioner pulley moving it down to release tension.
#17 | |
![]() Drives: 2016 Camaro SS Join Date: Jan 2019
EDIT AGAIN: 15mm clockwise for the tensioner with the spring/boot, then remove the 15mm bolt at top and 13mm at the bottom, leaving the torx bit and pulley bolts alone.
2016 Gloss Black Camaro 1SS, A8, MRC, 6-Piston BBK
Whipple, LT4 fueling, AlkyControl, Kooks, Borla, Roto Fab, Mightymouse, aFe, Apex, C7 Carbon, etc... Last edited by Dagstar; 04-02-2021 at 02:38 PM. |
#18 |
Drives: 2017 Camaro SS 1LE Join Date: Oct 2018
#19 |
There is no spring bolt. Only one bolt 15mm on the pulley, one torx bolt and 2 mounting bolts to the block.
#20 |
Spring/BOOT
Whipple, LT4 fueling, AlkyControl, Kooks, Borla, Roto Fab, Mightymouse, aFe, Apex, C7 Carbon, etc... |
#21 |
The new tensioner does not come with the bracket there is a 13 mm on the bottom of the cylinder there is a Torx bit on the top of the cylinder and then there is a 15 mm on the pulley I assume you turn the pulley clockwise to reduce spring tension.
#22 |
I just need to know where you place the wrench and which direction you go I assumed down to decrease spring tension on the pulley so I can remove the belt.
#23 |
I said above, 15mm socket on the tensioner and turn clockwise. The bolt on the pulley. Once you look at it with the belt you'll see how that will pull the pulley away releasing the tension.
#24 |
![]() ![]() ![]() Drives: 2016 Camaro 2SS Join Date: Apr 2018
Yes put your breaker bar on the bolt on the pulley and push down clockwise. After that just remove the two bolts in your picture and install the new one. You're going to have to push the tensioner down again to line the belt up but it's a super simple job and should take you no longer than 15mins.
#25 |
Thank you very much for your help.
#26 |
![]() ![]() ![]() ![]() ![]() Drives: '16 Camaro SS 6 spd manual transm. Join Date: Aug 2012
It failed on my '14 Corvette Z51, making a metallic tick noise at certain speed. It was replaced under the certified car warranty.
'16 Camaro SS
Prior cars: '14 Corvette C7 Stingray Z51 '14 Camaro ZL1 w/. Recaro seats '11 Mustang GT 5.0 w. track package '02 Porsche 911 Carrera '05 Infiniti G35 coupe sport |
