Old 07-11-2019, 03:28 AM   #15
RideZX6R
Probably tired right now
RideZX6R's Avatar
Drives: 1Lap1LE | EV6 FE | DenaliHD | E92M3
Originally Posted by pyroguy View Post
The higher you pay for the headers the greater chance that they will bolt right in without issue. The reason for that is that those companies took longer to R&D their headers and have higher Q&C standards. Now that doesn't mean that a pair of $500 headers won't fit right the first time, it just means that more consistently the more expensive ones will fit without "massaging" them to fit. On my 5th gen I bought Kooks and they were incredibly easy to fit and had plenty of clearance in all directions. I would recommend them to anyone looking for a set of headers.
My experience was the more expensive headers were a harder fit, so I don't know I'd agree with your generalization.
I will say that when vehicles are new to the market, the more expensive brands will be available sooner, as those companies typically are larger and have more resources/time to throw at fitting a new product. Whereas the cheaper brands will usually come later, in some cases copying or reverse-engineering products already on the market and/or improving upon them (sometimes).
YMMV
'17 SS 1LE - 1LAP 1LE (Now with more 447!)
'24 Denali Ultimate 3500 DRW
'22 Kia EV6 First Edition
'12 E93 M3
'25 911 (ordered)
Formers...
'18 RS3 (1 of 2) Cumulus Blue | '19 RS5 Sportback Sonoma Green | '07 Cayman S 6MT | '16 Audi S3 Prestige Viper Green (APR Stage 3+) | '19 Mustang Shelby GT350R | '17 SS 1LE MBM 575whp all-motor
RideZX6R is offline   Reply With Quote
Old 07-11-2019, 01:35 PM   #16
CompleteStreet
CompleteStreet's Avatar
Drives: 2018 Camaro ZL1 A10
Kooks fit perfectly with no issue. We have installed and sold hundreds of sets.
We keep them in stock, and have a free Jet Hot coating promo listed here-
https://www.cspracing.com/current-sales/
CompleteStreet is offline   Reply With Quote
Old 07-11-2019, 08:13 PM   #17
pyroguy
Keeper of “THE list”
pyroguy's Avatar
Drives: ABM #832
I will say that when vehicles are new to the market, the more expensive brands will be available sooner, as those companies typically are larger and have more resources/time to throw at fitting a new product. Whereas the cheaper brands will usually come later, in some cases copying or reverse-engineering products already on the market and/or improving upon them.
YMMV
That's an interesting experience. I've only installed Kooks and Stainless Works and both were super easy installs. However, many sets of Speed Engineering headers I've heard installed had to have at least one dimple in them to make them fit without rubbing. (These are just a couple examples of the polar opposites in price, I know other brands in-between that have issues/perfect fits as well.)
I do agree that the larger companies are able to do their R&D earlier which is why they come out with their headers sooner, and the cheap brands pretty much just reverse engineered theirs. That reverse engineering is likely why theirs don't fit as well as often too, combined with the typical lower standards of Q&C.
Check out my build thread
Old 07-12-2019, 01:58 PM   #18
RideZX6R
RideZX6R's Avatar
No experience with Speed Engineering personally so i can't comment.
I will say that the OBX headers I installed we're cheaper and an easier install than Kooks, not by a ton mind you - but enough to notice. Apart from the install the fitment was pretty similar, with the only major difference being that OBX had a little more room around the steering shaft (but there was a decent amount of room there to begin with so it wouldn't have swayed my decision if I were comparing the two).
'12 E93 M3
'25 911 (ordered)
Formers...
Old 07-15-2019, 10:36 AM   #19
Skyjogger
Drives: Colorado ZR2 (2.8 DIESEL) Camaro SS
I have a question do all headers need the engine mount removed or can some slip in easily ive seen conflicting info on this some people claim to have not had to remove engine mounts heck ive seen videos. and others claim there is zero way youll get headers in without removing mount.
Skyjogger is offline   Reply With Quote
Old 07-15-2019, 11:24 AM   #20
CompleteStreet
Kooks do not need engine mount removed.
Old 07-15-2019, 12:35 PM   #21
geaux_tigerss
geaux_tigerss's Avatar
Drives: 2019 GMC Sierra 1500 AT4
I did TSP 2" on jack stands in my garage and didn't have to touch the engine mounts. It's tight, but doable.
Summit White
6" Lift, 37x13.50R24's
geaux_tigerss is offline   Reply With Quote
Old 07-15-2019, 11:16 PM   #22
RideZX6R
RideZX6R's Avatar
I didn't need to do engine mount for kooks or obx.
I don't think you need to remove it for most headers tbh
'12 E93 M3
'25 911 (ordered)
Formers...
