Old 07-10-2019, 02:08 PM   #15
RideZX6R
Probably tired right now
RideZX6R's Avatar
Drives: 1Lap1LE | EV6 FE | DenaliHD | E92M3
552WHP AND 456 WTQ initially - some minor changes being made now - new dyno chart to follow
'17 SS 1LE - 1LAP 1LE (Now with more 447!)
'24 Denali Ultimate 3500 DRW
'22 Kia EV6 First Edition
'12 E93 M3
'25 911 (ordered)
Formers...
'18 RS3 (1 of 2) Cumulus Blue | '19 RS5 Sportback Sonoma Green | '07 Cayman S 6MT | '16 Audi S3 Prestige Viper Green (APR Stage 3+) | '19 Mustang Shelby GT350R | '17 SS 1LE MBM 575whp all-motor
RideZX6R is offline   Reply With Quote
Old 07-10-2019, 03:39 PM   #16
ULTRAZLS1
ULTRAZLS1's Avatar
nice.
although it looks like you chose to stay with unported heads? any reason?you are leaving a good 20-30 rwhp on the table without them.
Old 07-10-2019, 06:03 PM   #17
RideZX6R
RideZX6R's Avatar
nice.
I'm broke bruh :P
And 550whp is enough for now.
I might do a hi ram/hood and a 150 plate shot over the winter, if budget allows I'll port the heads.
'12 E93 M3
'25 911 (ordered)
Formers...
Old 07-11-2019, 10:10 AM   #18
G2K
@Blackmamba_1LE
G2K's Avatar
Drives: 2017 1LE
Id do the heads before the hi ram.... will give about the same power and dont have to cut your hood or modify the cowl.
Florida High Performance: H/C Whipple LME 377 900WHP
G2K is offline   Reply With Quote
Old 07-11-2019, 10:44 AM   #19
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Can you do this cam with stock exhaust manifolds? I really don't want headers on my car, too noisy/hot etc.....
Old 07-11-2019, 10:49 AM   #20
OVRKLL
Drives: 2017 1SS 1LE...makes me go YeeeHaw!
Nice!
I can actually hear the horses galloping!
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late!
OVRKLL is offline   Reply With Quote
Old 07-11-2019, 02:33 PM   #21
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Sure, it just won't make as much power.
Old 07-13-2019, 07:51 AM   #22
Redlinez
Shifts under load
Redlinez's Avatar
I can't see doing a cam without already having headers. When you say noisy, what do you mean? A cam is going to make some noise.
22 Suzuki GSX-S 1000GT blue
Old 07-13-2019, 10:12 AM   #23
KingLT1
KingLT1's Avatar
He means that he doesn't want the increased sound level from the exhaust that headers produce.
Old 07-13-2019, 01:06 PM   #24
oldman
Drives: SS 6 speed of course
the factory headers are really nice, like the Z/28 headers. I would look for a cam similar to the Z/28 cam. Such a cam will be a little bit more radical on the smaller 6.2 but the overall curve should be similar just offset a few hundred rpm up due to the smaller 6.2.
Texas Speed has a AFM cam, so does comp. IMO TxSpeed does more RD and you really run into a potential lifter collapse with too much spring. I would go for a full cam and kit from a vendor that HAS AFM cars running for the last few years.
I don't think there is that much sans headers to be gained by going to a full AFM delete setup. But deleting the AFM does give you more choices, also lets you port the heads. So ported heads, decent Z/28 type cam, phaser limited to 20 degrees, factory headers, front cat deletes (move sensors behind secondary cats).. Pray ported intake, 95mm TB, green filter in cut housing.... would yield a very nice performance boost on a "stock car"
End of thread jack.. back to this REALLY nice NA setup!
Old 07-14-2019, 11:40 AM   #25
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
I really wasn't concerned on NOISE per se. Headers do give off more heat under hood, melted plug wires a concern. I like the lope and sound of a cam. The OEM headers are actually pretty good: 4-2-1 and sound good. The factory NPP sounds OK, may switch at some point. Will get the heads ported. I don't care about 1/4 mile times.....
Old 07-14-2019, 12:00 PM   #26
oldman
the 1 and 3/4 headers do offer more room for the wires. I am on the stock wires for years now, they do need routing and a few zip ties and one custom bracket ( 5 minutes and a strip of aluminum). That said Speed engineering has $60 bent sparkplug boot wires. Or you can put your own bent boot on a stock wire. Making your own wires was the norm for many decades. There is more heat and guys are cutting open the heat extractors on the hood, you will need to wrap the starter and the header in that location. If you do a search on my post and "header". I've done many write-ups / responses.
Even stock the 2" header has shown a HP increase and debatable mid range torque increases too. Yes I know, that ain't possible.
Old 07-14-2019, 01:33 PM   #27
RideZX6R
RideZX6R's Avatar
I'd just buy either bent boot wires or the little heat shielding tubes they make for wires if that's your main concern and noise isn't.
I have OBX 2in headers and the car is loud at idle (as you heard in the video), but since that kit keeps NPP, the car closes the valves are low throttle/cruising so the car is really quiet in city driving besides taking off from lights and when you hit the throttle very aggressively. Definitely livable.
If you force the car into stealth mode, you hear the cam still in the idle but it's really pretty mild.
'12 E93 M3
'25 911 (ordered)
Formers...
Old 07-14-2019, 01:37 PM   #28
6spdhyperblue
Drives: 2SS 1LE
Wrap or coat your headers guys in addition to the prep mentioned above
