Old 06-26-2019, 04:21 PM   #15
BlaqWhole
Drives: 2017 Camaro ZL1 A10
All that could have been saved if they had just thrown a manual release somewhere in the car. I mean, would it have killed them? This must be the reason why the Camaro is doomed...
Old 06-26-2019, 09:28 PM   #16
closs2sx
closs2sx's Avatar
Drives: 1970 chevelle
I can help I have manually opened my trunk when I my car was being clear bra'd. I will pm my info
On Order 2018 ZL1 1LE Garnet Red Tint Coat Metallic
MY Car
2015 Z06 Z07
Daytona Sunrise Orange Metallic
Dads Car
2013 ZL1 vin 963
Crystal Red Tint Coat/Black Wheels
Exposed Carbon Fiber Insert
6 Spd Manual
closs2sx is offline   Reply With Quote
Old 06-26-2019, 09:33 PM   #17
closs2sx
closs2sx's Avatar
For what it is worth, I ran across this; Bulletin #16-NA-369 earlier today.
It appears that this is a variant of the standard ZL1 for weight savings.
https://www.camaro6.com/forums/images/attach/jpg.gif
MY Car
2015 Z06 Z07
Dads Car
2013 ZL1 vin 963
6 Spd Manual
Old 06-26-2019, 09:35 PM   #18
closs2sx
closs2sx's Avatar
that's what I used
MY Car
2015 Z06 Z07
Dads Car
2013 ZL1 vin 963
6 Spd Manual
Old 06-26-2019, 10:05 PM   #19
RSFR
RSFR's Avatar
Drives: ZL1
Been there done that.
RSFR is offline   Reply With Quote
Old 06-26-2019, 10:08 PM   #20
Sakudog
Sakudog's Avatar
Drives: 2019 ZL1 1LE A10
ANY TIME you disconnect the battery in the Camaro, you take a towel and you fold it in quarters and lay it over the trunk latch. Remember that for next time.
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Sakudog is offline   Reply With Quote
Old 06-26-2019, 10:13 PM   #21
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
How about unlatching the hood and hooking up a spare battery to the jumper posts? Then you'll be able to pop the trunk.
edit: I see it was already suggested and problem already solved. Yay!
Originally Posted by rlarsen462 View Post
Just for clarification I had the key and the doors weren't locked, just the trunk was closed.
Since I only disconnected the negative, I pulled up my truck and hooked jumpers to the connections under the hood and this powered the car so that I could pop the trunk with the electronic button.
Old 06-27-2019, 01:58 AM   #22
donaldp
Drives: 2017 Red Hot ZL1 M6
Red trunk lid, blue car???
donaldp is offline   Reply With Quote
Old 06-27-2019, 06:57 AM   #23
Sakudog
Sakudog's Avatar
They were in the middle of a Time Attack event, switching trunks was quicker than removing/installing wings. Pretty smart until the trunk thing happened but when you're on track, goofy shit happens because you're all over the place.
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Old 06-27-2019, 06:59 AM   #24
Sakudog
Sakudog's Avatar
I LOL'd when I read this, simply because I thought about how simple, obvious and correct this statement is now that I've read it. I think of myself as a pretty smart guy, but when I was reading through the problems I thought about mitigation (how to avoid doing it) not how to help them fix it in an easy way and if you have access to the cabin, this IS the best way. Bravo.
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Old 06-27-2019, 07:47 AM   #25
Grumpy1
Grumpy1's Avatar
Good advice......
Grumpy1 is offline   Reply With Quote
