Old 07-08-2019, 11:29 AM   #15
AZ_1LE
Drives: 2019 ZL1 1LE
Originally Posted by FNxR3DNECK View Post
Basically the issue is the 205/30/20 is too tall. With that said I'm very tempted in picking up a set of G3s in the new 19" sizes after I go through my current set of RS4s, the 305/30/19 G3s should work just as good as the RS4s/RE71rs. Of course you have to have some 19" wheels to do that.
It's not really that they're too tall, it's more a combo of putting a 305 tire on a 10" wheel which is going to create a lot more sidewall flex, plus a wheel that has an offset to close to the strut. This is why the 1LE wheels work with 305's on regular ZL1's, the wider wheel plus more offset allows the setup to clear the strut (barely, as long as you don't max out the camber).
Old: 2017 SS 1LE
Old: 2017 ZL1
Current: 2019 ZL1 1LE
AZ_1LE is offline   Reply With Quote
Old 07-08-2019, 01:30 PM   #16
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
But it's not too tall. At least on my mock up of a rear wheel with 1" of spacers it's not.
Old 07-08-2019, 01:31 PM   #17
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
Originally Posted by 5senna5 View Post
The interference with the tire is further up as it actually makes contact with the outer lower edge of the spring perch. There’s no way to modify that area like grinding on the strut tab for wheel clearance. Running a 5mm space would move it out far enough, but then you’re dealing with not enough thread for proper lug purchase. Longer bolts would be needed which negates using them on the front with little hassle. In short, it just doesn’t work on a practical level.
No it's too tall, it rubs on the spring perch (which is above the tire) not the strut (which is inboard of the wheel/tire). a 305/30/19 setup works with a lower offset wheel as long as you grind the strut down or run a spacer, the rubbing on the spring perch would still be an issue on the 19s if the tire was taller. The ZL1 1LE wheels/tires setup works on a regular ZL1 because like I said the tire is shorter than the 305/30/20s, you still may need to do the strut mod to get max camber out of that setup (I'm not 100% sure on this). Either way I think the best option is to go to 19s regardless of what tire you want to run, but I know that isn't the best option for some people.
IG: @NC_M1SS1LE
Old 07-11-2019, 05:59 AM   #18
madscotsman
Drives: 2018 SS 1LE
I have 295's on the front of mine and there is barely enough room to fit a finger tip between the tire and the spring perch.
madscotsman is offline   Reply With Quote
Old 07-11-2019, 10:12 AM   #19
TheRealJA105
Drives: 2013 C6Z06
A regular SS front tire is 27.7 tall and the 305 G3 is 27.2 tall. To say it is too tall is incorrect, but the spring perch has a little step in it towards the inside so the tire is too wide/rim offset incorrect for how tall it is. With a small spacer this will work. I'll probably try this after I thrash my set of 285s being mounted today although I'm still worried about the sidewall bulge and if it will roll over.
Old 07-11-2019, 10:27 AM   #20
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
With all the other upgrades you've done to your car why not go ahead and get a set of 19" wheels??? Even if you really like the G3s (can't blame you they're awesome!) with the new sizes arriving soon you could run a 19x10.5 square or event 19x10.5(or 11) front and 19x11(or 12) rear and go anywhere from 305 square to 305/325. And it would be easy to step up to the G3R later if you want!
IG: @NC_M1SS1LE
Old 07-12-2019, 07:51 AM   #21
TheRealJA105
Drives: 2013 C6Z06
Oh lot's of reasons, but most of them all come down to cost. I don't like to call myself cheap (although my friends do), but my decisions are highly based on $/improvement.
Old 07-12-2019, 08:39 AM   #22
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
Totally understandable! BUT... if you consider a 305 square setup that you can rotate the 19" setup is definitely worth it in the long run!!!
IG: @NC_M1SS1LE
Old 07-12-2019, 01:58 PM   #23
GTSLOW
Daily Driven 1LE
GTSLOW's Avatar
Drives: 2018 1SS 1LE
And what is the width of that regular SS front tire? The rim is considerably different too. Many have laid out why running the 305 up front on the stock wheel is a bad idea. It seems you came into this with a made up mind simply trying to convince us. It's your car, if and when it runs you can deal with that.
2018 1SS 1LE
GTSLOW is offline   Reply With Quote
Old 07-12-2019, 09:58 PM   #24
TheRealJA105
Drives: 2013 C6Z06
Everything i said is correct, no convincing needed.
Old 07-12-2019, 10:56 PM   #25
Dixie ZL1
NOXQCES ZL1
Drives: 2017 Camaro ZL1
Camber plates would resolve this issue. 305/30 square on the stock
20” wheel would justify the cost of the plates pretty quickly.
Dixie ZL1 is offline   Reply With Quote
