06-22-2019, 11:09 AM | #15 |
I would suspect that the main reason that it’s limited to 155 mph is because it is a convertible! I can’t imagine what it would look like if a vert flipped and rolled over due to an accident at that speed or above! Most likely whoever is in the car would be killed and the car completely destroyed! Of course if a coupe had a similar accident then the passengers would be killed too. Maybe it’s something to do with Insurance companies because it costs more to insure a convertible with State Farm than my ZL1 coupe or the SS coupe I had. Just my observations on the subject and not putting up an argument for or against.
06-22-2019, 12:37 PM | #16 | |
Drives: '18 Camaro 2SS VERT Join Date: Jun 2019
06-22-2019, 05:14 PM | #17 | |
06-22-2019, 05:39 PM | #18 |
Drives: Camaro 2SS & ZL1 Join Date: Mar 2018
Where are you going to be going over 155 anyway? Not too many tracks would have the room in a stock geared car.
2017 Camaro 2SS A8 Bright Yellow NPP MRC
2023 Camaro ZL1 A10 Radiant Red |
06-22-2019, 07:37 PM | #19 |
Yes but I think the whole purpose of this car, and the reason we all bought it, is solely based on something only males understand, and that is the notion of “not because we will or because we need to, but because we can”. Just knowing we have the ability to do something is what I’m after.
06-23-2019, 05:23 AM | #20 | |
Drives: 2017 Camaro SS Join Date: Nov 2018
But the exhilarating lightning quick acceleration that presses you into your seat - that's the thing I love about it.
Kevin
Luceo Non Uro |
06-23-2019, 06:08 AM | #21 | |
Drives: 2017 Camaro 2SS FIFTY convertible Join Date: Sep 2014
06-23-2019, 08:40 AM | #22 |
I need to add three things:
1. My guess is 99.9% of all Camaros never get over 150 mph.... ever 2. When the top is down, the sound and feel of 455 pounds of ground pounding torque can’t be heard and felt the same as when the top is up with the windows down. Top down, it feels like driving a go cart on steroids. A coupe feels safer, so the illusion of speed and danger (adrenaline) is not at the same level. Just like a go cart makes you think you are going faster than you are.... 3. I happen to think the coupe looks better with the reverse Mohawk, but I would still choose the vert, mostly because it’s faster. (See point 2) |
06-23-2019, 08:57 AM | #23 | |
Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
Made me laugh.
06-23-2019, 11:11 AM | #24 |
I still can’t understand why someone would want to go over 155 mph in a convertible! I wouldn’t be riding in one at that speed or faster! It’s just me though.
06-23-2019, 08:36 PM | #25 |
Drives: 2019 ZL1 1LE Join Date: Mar 2014
Yeah I mean 155+ even a coupe your odds of survival are pretty low. On a vert your dead. The loss of structure seals that fate. I mean not much better chance in a coupe but you might live after being cut out. Your quality of life will be pretty bad but slightly better chance then a vert.
06-24-2019, 09:26 AM | #26 |
Drives: 2019 CLA 450 Mercedes Join Date: May 2016
I would just add that the limiting factor on both the coupe SS and coupe ZL1 is drag. The big chunk of metal needing to push a hole in the air takes a lot of horsepower. The convertible would have much more drag with the top down and likely more drag with the top up.
I put this in another thread along with the comment that I have no clue about the drag co-efficient of the Camaros (or Mustangs in that thread) and do not care to dig to find out (I don't care). At these speeds (155, 180 or 200 miles per hour) the forces of physics are staggering. Ask Richard Hammond. He's been subject to these laws of physics, more than once. He is still suffering from memory issues from the last encounter.
2019 Lunar Blue Metallic Mercedes CLS 450
2021 C43 AMG Mercedes Coupe Metallic Cardinal Red 2014 Lincoln MKT EcoBoost (The Bus) |
06-24-2019, 04:30 PM | #27 |
Maybe that’s the reason the ZL1s aren’t doing well in NASCAR this year and last! They have too much drag and of course the recessed grill area doesn’t help either! Of course the racecar is a lot different to the street version anyway.
06-24-2019, 04:32 PM | #28 |
Agreed bignaz!!
