#15 | |
![]() Drives: 2018 ZL1 1LE - HBM, PDR Join Date: Jun 2017
GM typically uses narrow band O2 sensors. The factory narrow band sensors work with the factory ECU. They don’t tell you what the actual AFR is. They only tell you if you are above (leaner) or below (richer) than commanded lambda (AFR). The wideband will actually measure specific AFR which is need for tuning. The factory narrow bands must remain as that is what the ECU uses to make fuel adjustments.
JRE Tuned (HPTuners) | 15% OD (9.17" crank pulley) | TVS2300 Maggie Heartbeat Supercharger - 14 psi | E-50 (DSX Flex Fuel kit) | JMS FuelMax Fuel Pump Booster | LPE Big Bore High Volume DI fuel pump | LPE High Flow DI fuel injectors | LT5 95mm TB | RotoFab CAI | AEM X-Series OBD2 wide band gauge | Elite Engineering E2-X catch can | Borla S-type NPP Cat-Back 3" exhaust | Forgeline GTD1 5-lug Satin Graphite | SunTek wrap | C-Quartz Finest Reserve ceramic coated
#16 | |
Pretty easy. Remove the 4 bolts at the factory header collector to the primary cat. Then remove those same studs from the factory header. Do the same with the two nuts and studs on the flange mounting the primary to the secondary. It drops right out.
#17 | |
![]() Drives: 2018 Camaro 2SS Redline Join Date: Mar 2019
Interesting. On Harleys we can replace the NB, plug the bungs and just use the WB with the appropriate tuner. The tuner tells the ECM what to read. |
#18 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
The car runs using feedback from the narrow bands 90+% of the time. It but the computer ignores them at WOT or Open Loop so we need the Wide band to know if the calibration is achieving commanded AFR. Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
#19 | |
Learn something new everyday. |
#20 |
![]() Drives: Chevrolet Camaro ZL1 1LE Join Date: Apr 2019
Ted,
Do you have any experience with a wideband like the Dynojet Wideband2 which has the function to provide emulated narrowband output? I was thinking you could then only use widebands and emulate the narrowband for the stock ECU. |
#21 |
Sorry I do not.
#22 | |
![]() Drives: 2016 Camaro 2SS Join Date: Dec 2015
Thanks to Ted also. |
#23 |
@texan.1le
Drives: '18 Camaro 1SS 1LE, PDR Join Date: Jun 2018
Any concerns about the angle which your WB/bung are mounted? I'm about to add an AEM wideband to my factory exhaust in the same location (thanks to your pictures!!!) and the AEM documentation says that the sensor can't be tilted down and needs to be tilted "up" by about 10* (connector side up, sensor tip "down") to prevent condensation build up in the sensor tip.
'18 1SS 1LE - "Mongoose"
'15 Malibu 2LT - daily |
#24 |
![]() Drives: 2019 ZL1 Crush Join Date: Jan 2019
Not sure how long condensation would last being that close to the heads, the heat would remove it in seconds
2019 Crush A10
E-Force 2650 670WHP 615WTQ All besides the 2650 is bone stock down to the air filter. |
#25 | |
@texan.1le
https://www.aemelectronics.com/files...ller-Gauge.pdf Looking at TMS's photos again above, it may not be an issue since the pipe at that location is not 100% vertical and the O2 sensor, if the bung is welded perpendicular to the pipe with no angle, wont be 100% horizontal. The angle his installed pictures were taken from might be throwing off my perspective some.
'15 Malibu 2LT - daily Last edited by Z0Tex; 12-03-2019 at 02:40 PM. |
#26 |
![]() ![]() Drives: 2017 50th Anniversary 2SS Join Date: Sep 2016
I built a Timing Circuit that delays the Wideband from heating up and working for about 1 minute in order to give time for any heavy condensation to evaporate.
Its a nice little harness I made complete with a 12volt relay. There are only 3 wires to connect. Ground, your regular 12volt Power and the there's a 12 volt OUT that is the one that has the 1 minute delay. I can send you info on it or mine is avail for $45 PM me if interested.
#27 | |
Wideband
This. It’s perpendicular. It probably angles down very slightly. However, never a problem that I’ve experienced. Also, AEM likely expects that the wideband signal is feeding an ECU for dynamic air/fuel adjustments and obviously would want the optimum position. This is not the case of the wideband on our applications. It is simply to acquire data for logging and after the fact tuning adjustments. The narrowband sensors are retained and used for real-time adjustments. I think the warning is probably less relevant in our case. Just my thoughts.
#28 |
JRE posted last week that, if properly calibrated on the dyno(?), our Gen 6 tunes should not require future adjustments. You're indicating here that is not the case.
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
