Old 06-06-2019, 06:20 PM   #15
regnouy37
regnouy37's Avatar
Drives: 2019 ZL1 A10
Originally Posted by Redline Motorsports View Post
check out post #7 there is a link on a test we did it has some good info and pics. The 2650 is the latest from the TVS rotor family. The rotors are twisted in a unique manner that make them efficiency. Part of efficiency is the ability to move more air mass with less heat. All forms of forced induction devices have a certain efficiency range they work in...this being a supercharger (both positive displacement and centrifugal) as well as turbos.
The 2650 has a much better efficiency where GM runs it on the LT5 and that efficiency carries well up into 20 lbs of boost. They also took some drag out of it so it frees up power. Edelbrocks 2650 has a huge cooling brick and when combined with a matching heat exchanger you can solve a lot of IAT problems which again equates to more performance.
The above statement is clinical fact but I'm sure it will be debated by the trolls...
Thanks for the thorough explanation. What are your thoughts between a Whipple and the Edelbrock 2650?
regnouy37 is offline   Reply With Quote
Old 06-06-2019, 08:08 PM   #16
2out2sea
Drives: 2018 hyper blue ZL1 1LE
Originally Posted by Dixie ZL1 View Post
More inlet airflow creates a larger post rotor airmass, hence greater boost. The stock snout is a large restriction, so increase flow past that and you have a larger volume of compressible air and therefore more boost.
Boost is a simple function of restriction, so port the blower and heads after the ported snout and boost will decrease.
Makes perfect sense. Thanks for making it KISS simple for me...
2out2sea is offline   Reply With Quote
Old 06-07-2019, 07:43 AM   #17
Markoz28
Drives: 18 ZL1 nightfall grey A10
The 2650 looks awesome and has been proven to make big power but at a bit more cost due to clearancing the hood to fit. Thats why I’m leaning toward porting the stock SC/103 TB or Mag 2300. The struggle I’m having is whether there is a noticeable benefit going with the 2300 if I am not upgrading fuel system? Car is bolt ons only, no cam.
With a 5k budget (already have headers/intake/9.1 pulley) would it be better to do ported SC/103 TB and using the rest else where?
Markoz28 is offline   Reply With Quote
Old 06-07-2019, 08:21 AM   #18
staples87
Drives: 2017 Camaro ZL1
If you're thinking about going with the 2300 then I would stick with the stock blower, port it and run the 103 throttle body - It'd cost less. The bigger blowers shine when you have more supporting mods to go with them (cam, low side pump, methanol, ect), and when you end of spending that much money on a 2.3L blower, you're better off going with the 2650 since you'll be forced to have the supporting mods anyway.
'17 Camaro ZL1 M6
staples87 is offline   Reply With Quote
Old 06-07-2019, 10:03 AM   #19
Redline Motorsports
Redline Motorsports's Avatar
Drives: Several...
Well stated and on point...all about physics!
Redline Motorsports is offline   Reply With Quote
Old 06-07-2019, 10:06 AM   #20
Redline Motorsports
Drives: Several...
Check out the link in Post #7. Its about a Whipple install on a stock ZL1 against the 1700.... more food for thought.
Old 06-07-2019, 10:21 AM   #21
Redline Motorsports
Drives: Several...
Well.....I am very tight with both manufactures so its a hard line....lol...this is my opinion only based on how much time I spend on the dyno with these manufactures trying to do comprehensive and detailed testing.
The new 2650 is like the big brother to the old 1900....the 1900 was an amazing little blower and often kept up with the 2300. The TVS rotor design as I have stated before is very efficient in volume flow and most certainly temperature efficiency. For this even though its 2.65 liters it hangs with the 2.9 pretty good. I do think that at all out max power, around 1000 BHP, the Whipples slightly larger volume with pull a bit harder on the top.
Edelbrock tends to really optimize there runner lengths which promotes more low end and mid range, where Whipple runs a short runner.
If you look at a boost curve from both you can see this as the Whipple curve looks like a flat table top and the Edelbrock has a higher boost curve and tails off...
Both are great units and neither will disappoint!
Old 06-07-2019, 11:01 AM   #22
regnouy37
regnouy37's Avatar
Thanks for that!
Old 06-09-2019, 07:45 AM   #23
Redline Motorsports
Drives: Several...
Thanks for that!
Old 06-09-2019, 08:16 PM   #24
WFO220
living on the edge
WFO220's Avatar
Drives: 2018 ZL1
sounds like the best bang for the buck is the kong porting and i bet it would pass by warranty with no issues just on a visual . how much is it ? thanks REDLINE for the good read
WFO220 is offline   Reply With Quote
Old 06-09-2019, 10:06 PM   #25
Markoz28
I agree completely.
$1275 for the porting
$650 for the 103 TB.
Total= $1925, add about $100 for shipping I think. So about 2k for 40whp sounds pretty good.
Old 06-10-2019, 08:28 AM   #26
unavailablezl1
unavailablezl1's Avatar
Drives: 2019 Silverado Z71 6.2L A10
I was impressed with what I saw on your site. I am closing in on the end of my warranty and was looking at upgrades.
If Redline does the work in Florida and I live in Texas, where could I take it if there is a problem?
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's.
Past Rides
2017 M6 Camaro ZL1 Hyper Blue
2016 M6 GT350 White with blue strips
2014 M6 Mustang GT Premium Track Pack Ruby Red
2012 M6 M3 Melbourne Red Metallic
unavailablezl1 is offline   Reply With Quote
Old 06-10-2019, 10:19 AM   #27
Markoz28
I’m sure there’s lots of shops in Dallas that can set you up. You can order the parts from Redline and have a shop closer to you do the install.
Old 06-10-2019, 12:11 PM   #28
unavailablezl1
Yes I guess I could, but then it wouldn't be a "Redline", just saying.
Current ride
Past Rides
