Old 06-02-2019, 05:23 PM   #15
RealG
RealG's Avatar
Drives: 2024 2SS
So ,
Does the new LT1 have the same suspension, cooling and brakes as the SS ?
Many were saying that this new low cost V8 would be missing a lot of those things. some were saying NO the V8 should be the same as the SS. Do we have that answer yet ?
Thanks
RealG is offline   Reply With Quote
Old 06-02-2019, 09:59 PM   #16
GearheadSS
GearheadSS's Avatar
Drives: 23 LT1/86 IROC-Z
Originally Posted by RealG View Post
So ,
Thanks
It has the same suspension but like many of us guessed, it does not have the same cooling. No external engine oil cooler, no extra capacity cooling system, no auxiliary engine coolant cooler, no rear diff cooler.
It does have Brembos but FRONT only. Rear brakes are standard LT brakes.
It really is a base LT with the LT1 V8 dropped in. The only real upgrades(other than engine and transmission) over the LT are the base SS suspension, the front Brembos and the 20" wheels(instead of 18").
Old 06-02-2019, 10:02 PM   #17
GearheadSS
GearheadSS's Avatar
Originally Posted by Lynix View Post
Finally! So when will we see and find out what the Shock and Steel edition is? If it is some color combo between Satin Steel and Shock that would be amazing, at this point that’s what colors I’m torn between when I order my 2020.
NEW! Shock and Steel Special Edition, includes (Q7F/56Y) 20" blade design aluminum wheels, Carbon Flash-painted outside mirrors, center stripe [Silver when (GKO) Shock is ordered; Shock when (G9K) Satin Steel Metallic is ordered], (SHT) spoiler stripe, (5V5) Body-color wing spoiler, LPO, (VQL) Fuel filler door in Black with visible carbon fiber insert, LPO, (J55) Brembo 4-piston front, performance brakes, (J6E) Yellow-painted calipers, (S0U) Black sueded knee pads, LPO, (3DL) carbon fiber instrument panel molding and (VYW) Premium carpeted floor mats, LPO
1 - Not available at start of production. Also includes (WRS) RS Package. Requires (H0Y) Jet Black interior and exterior color (G9K) Satin Steel Metallic or (GKO) Shock.
2 - Not available at start of production. Requires (H0Y) Jet Black interior and exterior color (G9K) Satin Steel Metallic or (GKO) Shock.
Appearance package available on 2LT, 3LT and 2SS.
Not a combination of the 2 colors, orderable in either Shock or Satin Steel Metallic.
Old 06-06-2019, 09:01 AM   #18
blazzin1
blazzin1's Avatar
Drives: 2010 2SS/RS R6P
So, if I’m reading this correctly, the A8 is no longer available with the V8 cars. The A10 is the only available option for an auto trans, even on the LT1. Is that correct?
blazzin1 is offline   Reply With Quote
Old 06-06-2019, 09:27 AM   #19
VQ35DE
Drives: 2013 / 2SS / RS / L99
Yes.
VQ35DE is offline   Reply With Quote
Old 06-06-2019, 09:38 AM   #20
IOMike
Drives: 2022 F150, 87 Monte Carlo
So ,
Thanks
Most said it would not have the SS suspension and the Brembos were not standard, but an option. It's basically a SS minus the extra cooling and standard rear brakes. It won't have the cooling for the track, but should make a great street car. Disappointed it doesn't have active rev match though.
IOMike is offline   Reply With Quote
Old 06-13-2019, 05:49 AM   #21
SteevK
SteevK's Avatar
Drives: 2017 2SS Hyper blue A8 NPP MRC
It's sort of a combo - Steel gets Shock stripe and Shock gets Steel stripe.
2017 Hyper Blue 2SS 8A K&N Typhoon w/Spectre blue filter, Vitesse throttle control, 2019 Camaro twisty rims with blue lugs, Blue "SS" badges
SteevK is offline   Reply With Quote
Old 06-13-2019, 06:07 AM   #22
SteevK
SteevK's Avatar
LT1 is like the 3rd & 4th gen Firebird Formula - engine, trans, susp of a Trans Am, in a base coupe looking wrapper - a factory sleeper.
Get NPP, 275s on the back, de-badge it, get a body-color hood vent, and go hunting.
Old 06-13-2019, 01:12 PM   #23
Baldman
EMERALD COAST CAMAROS
Baldman's Avatar
Drives: None
Baldman is offline   Reply With Quote
Old 07-28-2019, 08:58 PM   #24
D K
Drives: C5
Does anyone know if the 1lz either comes with lsd diff or has an option for it?
D K is offline   Reply With Quote
Old 07-28-2019, 09:04 PM   #25
95 imp
Dumb Ass Deluxe
PREACH, BROTHER, PREACH!
Old 07-29-2019, 10:36 AM   #26
GearheadSS
GearheadSS's Avatar
Yes, it comes with limited slip diff.
Old 07-30-2019, 06:50 PM   #27
Gatorcamaro
Gatorcamaro's Avatar
Drives: 2020 camaro zl1
Just ordered 2020 zl1...can't wait
Gatorcamaro is offline   Reply With Quote
Old 07-30-2019, 09:26 PM   #28
Chevyfan4life
The Green Hornet
Chevyfan4life's Avatar
Drives: 2020 Rally Green 2SS 1LE
Grats.
you can check with Becky and she give you status on your car.You can find her here.
https://www.camaro6.com/forums/showthread.php?t=415251
XCMKZ4- 2020 Rally Green 2SS 1LE
1100-07/02/19
3100-07/04/19 | TPW 8/5
3400-7/29/19
3800-8/2/19 Built!
4300-8/5/19
4300-8/9/19 delivered to rail yard
4200-8/13/19 Shipped!
5000-8/19/19
6000-8/24/19 She's Home!
Chevyfan4life is offline   Reply With Quote
