#15 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
Stock oil filter per the manual here.
#16 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
use a blue AC Delco PF-64 and don't get fancy.
#17 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
My cap says 5W30 on my 2017 ZL1. I would use the oil grades your owners manual states. Simple and easy and done!
#18 |
Drives: 2019 Camaro Zl1 1Le/ '18 M4 Join Date: May 2019
Did you all do a 500 mile/1,500 mile oil changes during break in phase? What intervals? Just street driving, no track yet
#19 |
Who Needs to KNOW?
Get the good stuff
![]() Are you in the NY/NJ/PA/CT region? Join us for autox fun at MetLife Stadium. HUGE lots, tons of runs. http://www.motorsportsne.com/ |
#20 |
#21 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
Use the factory recommended oil and filter. You gain nothing by doing otherwise.
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
#22 |
![]() Drives: 2019 Camaro ZL1 1LE A10 Join Date: Sep 2019
This is an old thread but, is anyone using a ZL1 1LE for autocross? What oil weight are you using? I've had issues in the past with too thin and too thick of oil while autocrossing.
#23 | |
Assuming the motor is properly warmed up before any runs i dont think you could go wrong with it. Having said that, many here track their cars (non ZLE models) on sticky tires incl slicks and by and large (i believe), run 0 or 15W40. So, this is a bit inconclusive, as GM doesn't state that other Camaros must run thicker oil on stickier rubber... Bottom line, if warranty is a consideration, then I would run what the manual specifies. Cheers! |
#24 | |
2018 ZLE - M6, Nightfall Gray
GM previously owned: 2014 SS M6 2014 ZL1 M6 2019 ZL1 M6 2016 Z06 M6 |
#25 | |
Hope this helps. Cheers! |
#26 | |
#27 | |
But, GM switched factory fill to 0w40 and hence all newer cars now say 0w40. Because GM dealers carry it now ![]() |
#28 |
![]() Drives: 2022 ZLE 6M Join Date: Jun 2021
After the first 500 miles, I switched to Motul 5W40 and I'm going to use it for track and street duty.
If I would drive the car in freezing environments, I would go with 0W40. https://www.motul.com/fr/en/products...an-gen2-5w-40# |
