#15 | |
![]() ![]() ![]() ![]() Drives: 2018 ZL1 (SOLD) 992 GT3 (current) Join Date: Aug 2013
Edit Update #17457 seems to more about electrical readings, gauges and power steering #17468 seems to be about the ABS, also different symptoms than what I'm experiencing #18258 has the closest symptoms, but if this is what the problem is, I'd think it would happen more often, not just after long hard corners.
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
#16 |
UPDATE
Dealership said it's the 2nd defective fuel pump in a row... I find it a little hard to believe I could have this bad of luck, is there anything else that could be causing the fuel pump to prematurely fail twice in 1 year?
#17 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
Unusual for sure, but maybe this one will be reliable. At least the dealer found the problem pretty easily. Haven’t read about a lot of fuel pump failures.
#18 |
![]() ![]() ![]() ![]() Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
That's very strange, dont know anything about the pump but all fuel pumps I've worked with hands on (Walbro, Ti) have been very durable under harsh conditions with a lot of modifications.
Pumps can fail from overheating or wrong voltage. Also, running a non-E85 pump with E85 can wear one out eventually. Do you run E85 or completely stock? |
#19 | |
If the fuel pump was defective i would think this problem would happen all the time under WOT.
#20 |
![]() Drives: gas powered Join Date: Jan 2019
Possible the first pump put trash into the system and the second one either bought the farm from restriction,junk in the tank, or just plain old didnt replace it correctly. if its sucking air, cavatating the pump it will kill it quick.
We had an astro van v6 it ate about 4 in 125k miles. Never did really figure it out and the wife lost confidence in it so we cash for clunkered it. I generally dont run any vehicle with a in tank pump lower than 1/4 tank since the fuel helps cool the pump. |
#21 |
Apparently the "fuel pump" is an entire assembly of multiple components that includes pick up, air filter etc... and is about 12" by 8" so it sounds like each of those components in the assembly could fail individually, which would increase the chances of the "fuel pump' failing because it's not just a pump.
#22 |
UPDATE
Seems like it was the Fuel Pump Assembly for the 2nd time, after it was replaced I immediately did 4 hard long corners (on ramp loop to highway) at 1/4 tank and no problems!
#23 |
2019 ZL1 1LE MY GOON
Drives: 1980 Z28 Big Red. Join Date: Dec 2018
Good. Hopefully that’s the end of your fuel pump woes.
#24 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Challenger Hellcat, 2018 ZL1LE Join Date: Dec 2009
glad to hear you got it worked out. keep records of all this, if it keeps happening you might be in for a lemon law case
2018 ZL1 1LE/Red hot 2019 Shellby GT 350R/ Oxford white/ Matte Black Stripes/ Carbon Fiber Dash/ Electronics Package #413 |
#25 |
Nope, it just started doing it again...
I had 5 good track days and now it's acting up again on long hard sweeping corners, there is no way I could have 3 defective fuel pump assemblies in a little over 1 year, this is crazy, I don't know what this could be...
#26 | |
#27 | |
According to the story, you get the fuel pump replaced (low side or HP mechanical?) and then it's fine for awhile but then returns after heavy track use, is that right? If it's an electrical pump failing repeatedly, maybe you have an electrical issue that's wearing out these pumps over time. I have no expertise with this, and dont understand much about the ZL1 fuel system. |
#28 | |
I think I need to find a dealership that's willing to investigate the problem not just keep replacing the fuel pick up assembly, don't want this going on forever or after the warranty runs out.
| Tags |
| cornering, power loss, stumbling, surging, wot |
