Old 05-23-2019, 07:41 PM   #15
TrackClub
TrackClub's Avatar
Does the car run ok till empty without hard cornering?
Have you tested it?
Edit: have they checked for any codes?
Old 05-23-2019, 08:20 PM   #16
GunMetalGrey
GunMetalGrey's Avatar
Drives: 2018 ZL1 (SOLD) 992 GT3 (current)
Have you tested it?
Yes runs fine, I've been down to and past the LOW FUEL WARNING multiple times.
They did check the car for codes, the engine light had gone off, I didn't ask them what codes they found but I probably should
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
GunMetalGrey is offline   Reply With Quote
Old 05-23-2019, 09:23 PM   #17
TrackClub
TrackClub's Avatar
Well then my layman logic points to something loose that stops the fuel flow under high G, which causes hesitation coming out of a corner (as suggested by the explanation above) and then corrects itself. Maybe a sensor? If fuel pump was bad it would do it under any conditions, even if intermittently.
Then again, this is a pure guess again...
Old 05-23-2019, 09:28 PM   #18
TrackClub
TrackClub's Avatar
Here are two links that describe various root causes. Tons of others as well. In any case, good to have some generic understanding for your discussions with the service folks...
https://axleaddict.com/auto-repair/W...g-Acceleration
https://www.yourmechanic.com/article...by-tim-charlet
Old 05-23-2019, 10:56 PM   #19
GunMetalGrey
I agree!
Thanks, that will be helpful
Old 05-24-2019, 12:39 AM   #20
TrackClub
TrackClub's Avatar
Ive PMed ya re one of the TSBs mentioned in the other thread. It is defo worth checking. SS 1le had a harness issue a while back as well. Maybe the thing moves and shorts itself coming out of corners. Who knows...
Old 05-24-2019, 01:56 PM   #21
GunMetalGrey
Apparently the "fuel pump" is an entire assembly of multiple components that includes pick up, air filter etc... and is about 12" by 8" so it sounds like each of those components in the assembly could fail individually, which would increase the chances of the "fuel pump' failing because it's not just the a pump.
Old 05-24-2019, 03:04 PM   #22
driven2exceSS
driven2exceSS's Avatar
Drives: 2016 2SS BLK A8 Vert
Still odd luck to have multi pump failures. I guess if I had to choose between my bad luck and yours, I'd take yours. At least there is a warranty behind it, not not a judge and Ex-wife!! lol I'm very curious if your situation/symptoms will return though?? I'm surprised more people have not experienced this fuel issue when tracking!! I'd like to be able to run with less fuel, especially when trying to cut weight that generously comes with thy Vert. Maybe there is something up with mine as well?? Idk it's not an issue otherwise, unless doing exactly what you were (and I was doing) with similar fuel levels when symptoms occurred. Like I said my solution was starting with more fuel to prevent the "starvation". Thanks again for keeping us updated.
driven2exceSS is offline   Reply With Quote
Old 05-24-2019, 04:16 PM   #23
TrackClub
TrackClub's Avatar
Maybe it is time to ask the dealer exactly what they replaced each service. And raise a bit of hell with mgmt.
Old 05-24-2019, 08:10 PM   #24
Bluebarchetta
Drives: 2017 SS 1LE
FWIW, I’m not sure that the codes will be helpful. Modern cars run on thin air fuel ratio margins. Hence the power vs mpg we get. Anytime you get a lack of fuel the car is probably gonna freak out and toss a bunch of codes that will be more likely in regards to lack of fuel, but not likely to tell you why you have a lack of fuel.
Really hope you get to the root issue here.
Bluebarchetta is offline   Reply With Quote
Old 05-26-2019, 06:00 PM   #25
GunMetalGrey
Car is going in on Monday, will be testing it IMMEDIATELY after they are done, with 1/4 tank to see if the issue occurs again, will keep you posted.
Old 05-26-2019, 09:24 PM   #26
TrackClub
TrackClub's Avatar
Fingers crossed. Get all the docs from prior visits so you have a detailed paper trail and full understanding of exactly what they replaced each visit. My 2 cents and best of luck!
Old 05-28-2019, 09:29 AM   #27
GunMetalGrey
UPDATE: Took the car on 4 hard long corners around a highway on ramp loop on 1/4 tank and everything worked great every time!
Old 05-28-2019, 10:00 AM   #28
TrackClub
TrackClub's Avatar
Fantastic! What did they replace exactly?
Thanks!
cornering, power loss, stumbling, surging, wot
