Old 05-11-2019, 11:24 AM   #15
Alain
Alain's Avatar
Good.
I'm doing my Elite Catch can install sometime next week (weather permitting). Your pics and thread are helpful since i'll have to lift my supercharger up off the blocks to install the PCV
2018 ZL1 1LE/Red hot
Old 05-11-2019, 12:07 PM   #16
Fatty1707
Drives: 2019 ZL1 A10
Originally Posted by Alain View Post
Right on dude !!!! Glad to see someone tackling this in their garage and putting up pics as they go along. Keep the pics coming!!!!!
How are you addressing the refill of the supercharger coolant since the system is a closed system and it needs a special tool from GM to refill?
Coolant vacuum refill kit is what I used on the Mustang. Worked great. Am I missing something with the Camaro?
Fatty1707 is offline   Reply With Quote
Old 05-11-2019, 12:14 PM   #17
Fatty1707
Originally Posted by F419sr1 View Post
Took about 4 hours to get it all torn down. Most of it getting the bottom splash pan off to drain the coolant. Probably a easier way to do it. Started around 9:30 and I’m almost done. Had to run out for longer TB bolts.
WOW! And you are almost finished? This seems like a breeze compared to the mustang which included grinding, re wiring, etc...
Old 05-11-2019, 03:08 PM   #18
Alain
Alain's Avatar
as long as you have the correct fittings you should be good to go.
Old 05-11-2019, 04:45 PM   #19
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
Use a reservoir with this Whipple and the factory bleeder isn't used.
Old 05-11-2019, 10:00 PM   #20
SilverZl1
SilverZl1's Avatar
Drives: 2018 ZL1
+1 on adding a high point reservoir to eliminate air pockets and make fill/top off a breeze. ADM sells a small Edelbrock res kit that brackets to the drivers side strut tower and is simple to install. It’s the same one that comes with the E-Force blower kit. I believe Stephen12ZL1 did a nice install post on it.
SilverZl1 is offline   Reply With Quote
Old 05-12-2019, 12:00 AM   #21
Harry76
Harry76's Avatar
Drives: 2018 ZL1 A10 Nightfall Gray
Here's a pic of mine showing the catch can, flex fuel sensor and coolant fill reservoir.
Harry76 is offline   Reply With Quote
Old 05-12-2019, 07:20 AM   #22
Zigg L1
Zigg L1's Avatar
Drives: 2018 ZL1 Garnet Red Tintcoat A10
How do you drain the catch can? Do you have to take all apart? Its nice to get it out of the way but has got to be a pain to drain
Zigg L1 is offline   Reply With Quote
Old 05-12-2019, 11:21 AM   #23
Harry76
Harry76's Avatar
Hose out bottom of catch can, there is room beside the filter to reach the valve for opening it.
Old 05-12-2019, 11:35 AM   #24
F419sr1
F419sr1's Avatar
Drives: 2017 ZL1
Do you have a better pic of the cut out in the hood
Kooks full exhaust, Roto Fab, Whipple,Williams 103, Fore innovation, JRE cam and tuning
F419sr1 is offline   Reply With Quote
Old 05-12-2019, 04:58 PM   #25
Alain
Alain's Avatar
Wow dude. That’s the best mounting position for a catch can on an LT4 I’ve never seen. Nice work.
Old 05-14-2019, 09:31 PM   #26
Harry76
Harry76's Avatar
It's not as pretty as I would like, I plan on taking it apart and working on it some more one of these rainy days.
Old 05-15-2019, 06:29 AM   #27
F419sr1
F419sr1's Avatar
Drives: 2017 ZL1
Thanks I got a drawing from whipple. I having a template made at a local printer to make it easier. Iv been going back and fourth on weather to put it back on or just drive it for the season and deal with the rest over the winter. I did a lot of reading here on the whipple but missed the part on cutting the hood. I’m not a fan of mods I can’t easily return back to stock.
Old 05-15-2019, 09:00 AM   #28
Alain
Alain's Avatar
Dang!! I didn’t know the hood needed to be cut in order to fit a whipple.
That’s a curve ball I wasn’t expecting.
