Old 05-01-2019, 07:40 AM   #15
2out2sea
Drives: 2018 hyper blue ZL1 1LE
Seems like the easiest path. Anything further gets to the point of diminishing returns. I am hoping to hear the dyno results today. I'll post once I hear from vengeance...
2out2sea is offline   Reply With Quote
Old 05-01-2019, 05:30 PM   #16
VAZL1
VAZL1's Avatar
Drives: 17 ZL1
2017 ZL1 Coupe M6, Red Hot
Mods; AFE Pro 5R CAI, Kong Ported Blower and Snout, NW 103 TB, Griptech 2.31 Upper, Kooks 2",JMS Voltage Booster, Flex Fuel, Mighty Mouse CC,Jannetty Racing Tune, 680 rwhp
VAZL1 is offline   Reply With Quote
Old 05-01-2019, 05:34 PM   #17
mspeed1LE
mspeed1LE's Avatar
Drives: ZL1 1LE SUMMIT WHITE
Can someone tell me what exactly a ZLE is?
2018 ZLE * StudioRSR Half Cage * SkidmarkGarage Rear Seat Delete * ZL1ADDONS Lift Pads * Roto-Fab CAI * Forgestar CF5-V's * Michelin PS4S * Racequip 6 Pt. Harnesses * Sub-strap Brackets by Carmena Performance * Speedhut Shift Light * Leroy Eng. Hidden Hitch (for the TYR RAT)* Gen5DIY Rapid Flash 3rd Brake Light * KOOKS 2" LT * Green Cats * AWE Cat-back Track Edition *
________________________________________
2005 NISSAN TITAN
1997 BMW E39 (Thug In A Suit) R.I.P. 10/04/18
2002 MAZDA Protege 5 (Time Attack, Hillclimb) SOLD
mspeed1LE is offline   Reply With Quote
Old 05-01-2019, 05:41 PM   #18
VAZL1
VAZL1's Avatar
Drives: 17 ZL1
Short for ZL1 1LE
Old 05-01-2019, 05:53 PM   #19
mspeed1LE
mspeed1LE's Avatar
*DOH*
2005 NISSAN TITAN
Old 05-01-2019, 09:18 PM   #20
2out2sea
Ok, I got the results and I'm not very happy. Baseline was 566 which isn't bad for an 80* day. Today it was over 90*; the hottest day off the year, but she only made 629. This is with 2" coated kooks, green cats, rotofab big gulp, a ported stock blower, 2.3 underdrive griptec pulley, 103 katech tb, colder plugs, plug wires, catch can and full tune. I haven't seen the dyno graph yet so I am not sure about timing and iat. Car is only making 11psi boost! Shouldn't it be making more like 13-14psi? How is it that complete street performance made more power than this BEFORE adding headers! Not sure what to think at this point. Really not happy.
Old 05-01-2019, 09:35 PM   #21
Zl1steve
Drives: Zl1
Dont get worried about dyno numbers. I bet it hauls ass now. I have about same as you on my car except for ported blower and a vengeance mail tune. Never been on dyno but it went 135 mph in the 1/4 at 10.82 with a 1.98 60ft.
Zl1steve is offline   Reply With Quote
Old 05-01-2019, 10:22 PM   #22
Markoz28
Drives: 18 ZL1 nightfall grey A10
Ok, I got the results and I'm not very happy. Baseline was 566 which isn't bad for an 80* day. Today it was over 90*; the hottest day off the year, but she only made 629. This is with 2" coated kooks, green cats, rotofab big gulp, a super ported stock blower by a shop that will remain nameless, 2.3 underdrive griptec pulley, 103 katech tb, colder plugs, plug wires, catch can and full tune. I haven't seen the dyno graph yet so I am not sure about timing and iat. Car is only making 11psi boost! Shouldn't it be making more like 13-14psi? How is it that complete street performance made more power than this BEFORE adding headers! Not sure what to think at this point. Really not happy.
That’s pretty good considering the temps of the day. With the 2.3 pulley you would only see about 2 psi increase but with the SC being ported you lose restriction so the boost drops a bit so 11psi seems right.
What was torque numbers?
Markoz28 is offline   Reply With Quote
Old 05-01-2019, 10:24 PM   #23
Markoz28
Wow, get that 60’ yo at least a 1.7x and you’ll be mid 10s easy.
Old 05-01-2019, 11:32 PM   #24
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
Every car is different. CSP had the advantage of really cold temps when they did his shop ZL1 too. There's was no pulley but with headers, ported snout, Kong blower, 103mm NW TB, etc.
11 PSI does sound low...I trust Vengeance though. Maybe talk with Ron and just make sure everything is straight and if so, the track numbers will not lie.
Old 05-02-2019, 02:24 AM   #25
2out2sea
Tq was 631 after final tune. Thanks for the encouragement guys. It seems like mine is the lowest output I've heard of with similar mods. My reason for the choice of mods was seeing most guys making North of 650 before adding a ported blower. I am not sure what's wrong. I never wanted to build any kind of monster, but thought that I'd get more for the money than this.... Going to email David and see what ideas they have.
Old 05-02-2019, 03:38 AM   #26
GoneBoy
Drives: '17 ZL1
Tq was 631 after final tune. Thanks for the encouragement guys. It seems like mine is the lowest output I've heard of with similar mods. Me reason for the choice of mods was seeing most guys making North of 650 before adding a ported blower. I am not sure what's wrong. I never wanted to build any kind of monster, but thought that I'd get more for the money than this.... Going to email David and see what ideas they have.
You're not going to make 14lbs off that 2.3 griptec. 11 is safe and spot on, which is what mine made when they did the same pulley swap during my build
GoneBoy is offline   Reply With Quote
Old 05-02-2019, 03:51 AM   #27
2out2sea
Isn't 11 stock boost? The 2.3 is supposed to be 9% and increase boost to 13 according to everything I have read. Still trying to figure out why with the 103tb and p&p supercharger it's only making 11psi. I would be more understanding if she showed a weak baseline Dyno, but 566 seems pretty healthy. What else am I missing? I am hoping beyond hope that it was just complete heat soak, but we'll see.
Old 05-02-2019, 04:28 AM   #28
VAZL1
VAZL1's Avatar
Drives: 17 ZL1
My guess is you ran out of low side fuel pressure. The boost pressure seems right since you have the ported blower and no cats. I run around 13.5 with the same setup but I have high flow cats. Ask about your low side fuel pressure, see if that's the reason, if so I would be curious what there suggestions are
