Old 04-21-2019, 09:27 AM   #15
rlarsen462
Sell Low, Buy High
Drives: 2022 ZLE, 2023 ZLE (Inbound)
Originally Posted by 17CamaroZL1 View Post
A battery tender comes with a small connector that allows you to leave it connected to the battery and simply plug it into the charger. You could have the small plug sticking out of the battery compartment door just enough to make it a quick easy connection. You could also hook it to the underhood connections and find a spot you like up there to do the same thing.
Ironically the "Camaro" branded CTEK one that is the factory RPO option, just has hardwired alligator clamp leads, it's not like the other CTEK's I've seen with the removable plug harness. I guess Chevy cheaped out on their branded unit. Kind of annoying, I really wanted to just hard install the harness in the trunk as I back into the garage so putting it on the terminals in front will be a bit of a hassle.
rlarsen462 is offline   Reply With Quote
Old 04-22-2019, 08:56 AM   #16
sengli
sengli's Avatar
Drives: 2015commemorative vert 2SS
My most recent ZL1 came with the CTEK charger too. When My current tender dies, I am going to install the plug on that units output, to match the plug in the cars pigtail.
Its a lot easier to pop, the trunk via the factory button and access the wiring, than to have to open the hood every time. As thin as the sheet metal is on these cars, touching the hood is risking damage.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded
2015 commemorative vert 2ss
sengli is offline   Reply With Quote
Old 04-23-2019, 02:36 PM   #17
ZED-L1
Drives: '17 ZL1, '69 Nova SS
Even though my '17 was on the factory trickle charger while car sat over the winter in a heated garage, the battery was dead when I tried to start it up the other day. Power pack, direct boost...nothing worked. Had to have it towed to dealer to get warranty battery replacement. Dead cell issue. Dealer tells me it's a common issue with GM batteries and they've taken delivery of new vehicles with dead batteries.
ZED-L1 is offline   Reply With Quote
Old 04-23-2019, 05:13 PM   #18
Squatch
Camaro pilot
Squatch's Avatar
Drives: 69 Camaro, 2014 ZL1
My 2017 Colorado had a dead cell; warranty replaced.
2014 ZL1 Camaro
1969 Camaro
Squatch is offline   Reply With Quote
Old 06-12-2019, 08:13 PM   #19
ZL1Danny
ZL1Danny's Avatar
Drives: 2017 ZL1
I have had this issue with my 17 ZL1 twice now. I did leave it sit too long without starting it I guess. I mounted the trickle charger cord set under the hood at the remote terminals. The cover with the red button on it will unclip and there are (2) spare remote connection posts under that cover to pretty up the install. THOSE TERMINAL POSTS ARE METRIC a 1/4-20 nut will not fit on there.
I pull my car into the garage so under the hood works better for me, I am going to try and get those leads out through the grill or side vent so I don't have to keep opening the hood. I wonder what is in these cars that pull these batteries down? There are no lights or pumps running, surely the computer isn't doing it...
2017 ZL1 A10
Nightfall Gray
SW Headers and Pipes
Upper Pulley
RotoFab CAI
ZL1Danny is offline   Reply With Quote
