#15 |
![]() Drives: 2019 ZL1 Crush Join Date: Jan 2019
This car is so damn fun, 4th test hit. Getting closer to sub 4 second 0-60
Wont let me upload the video off my PC but went a 4.00 on the last hit. Race mode, dry, 1200 launch RPM. Per the video it was slipping the tires until I let off @ 90 in 4th |
#16 |
![]() Drives: 2019 ZL1 A10 Join Date: Oct 2018
You all using the built in 0-60 timer or another method?
Built-in usually yields 3.8 or 3.9 for me. One time best of 3.7. Had the kid in the car once, added another 160 lbs and pulled my worst (4.0). Also pulled a 3.8 on the next run (same passenger). All my best times have been Sport mode and stomp on it. Hard to practice technique on multiple attempts without attracting too much attention. All runs have resulted in a good deal of tire spin, if I could hook, 3.5 should be no problem. |
#17 |
Built in timer, keep in mind that I am almost @ 7k altitude so we lose a bit of the O2 up here
#18 |
#19 | |
I am curious to see if the hotter pavement helps with grip at all, that seems to be my most limiting factor. |
