Old 03-29-2019, 02:18 PM   #15
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
You guys are thinking too logically. He got a number of $800 for 1 front rotor and multiplied it by 4 to get $3200. He clearly knows nothing about the braking system, and that's how he got the number. He should trade someone with a regular SS front brakes to lower his costs because it doesn't sound like he will be going to the track.
Old 03-29-2019, 02:20 PM   #16
Osbornsm
Drives: 2018 SS 1LE
I demand part numbers for F (L and R) and rear rotors.
Anywhere reliable to look those up?
Thaaaaaanks
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si
Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8
Results: 470 hp / 447 tq
Osbornsm is offline   Reply With Quote
Old 03-29-2019, 02:22 PM   #17
TheRealJA105
Drives: 2013 C6Z06
Thaaaaaanks
Old 03-29-2019, 03:22 PM   #18
Osbornsm
Drives: 2018 SS 1LE
Crap, i saw all kinds of numbers in there...
Re-reading...
Old 03-29-2019, 03:39 PM   #19
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
I have no noise from the brakes, but they are the dustiest pads I've ever had on a car.
'18 1SS 1LE Black, PDR
Old 03-29-2019, 04:12 PM   #20
TRZ06
TRZ06's Avatar
Drives: 22' Porsche PDK GT4
A-hole mode back in play huh
Can't you post anything other than talking SH** about someone???
Current:
Previous:
09' C6 Z06
08' E90 M3
06' 335i (KW V2 Coilovers)
03' C5 Z06
Old 03-29-2019, 08:32 PM   #21
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Rears at RockAuto $74. wish the fronts where that much
https://www.rockauto.com/en/parts/ac...233,rotor,1896
Old 03-29-2019, 09:40 PM   #22
Adampau123
Drives: 2017 Red Hot 1SS 1LE
How many miles is everyone getting on oem rotors? I don’t do much track but drive somewhat aggressively. Have 15k miles on oem pads and doesn’t look like I have much pad life left. Wondering if I could resurface and do pads or just get new rotors.
Adampau123 is offline   Reply With Quote
Old 03-29-2019, 10:20 PM   #23
TrackClub
TrackClub's Avatar
If your rotors dont have deep or long heat checks (cracks) than they are still good. No need to resurface unless they are warped (and you'd know this) as this will only make them thinner, hence being counter productive to their life span. Just get new pads, bed them in and enjoy the car. Cheers!
Old 03-30-2019, 06:34 AM   #24
carguy55
carguy55's Avatar
Sounds like you need new pads which are easy to change before they reach the Brake Pad Wear tab.
What Trackclub said is one sign of needing new rotors, the other is if they're worn down they can reach the minimum (discard) thickness. For the fronts the discard thickness is 32mm, for the rear it's 24mm. The rotors do not require refinishing as part of routine brake system service like the old days.
Old 03-30-2019, 09:57 AM   #25
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
To the above point, you can wear the pads down past the wear tab (bend the wear tab back). However, you put more heat in the pad, rotor, etc. I only do that in a pinch where maybe I want one more session. As cheap as the pads are, especially the rear, I change all of them "early". The stock pads are a good HP1000 compound from Ferodo with pad and backing plate thickness ~9.5mm.
Watch for pad taper as you get more track time under your belt. Good luck and have fun out there. Your pad wear will vary greatly depending on pace, track, driving style, and PTM setting (or not).
RUQWIKR is offline   Reply With Quote
Old 03-30-2019, 12:16 PM   #26
Move_Over
Drives: ISO ss 1le
Am i reading a thread about rotors rusting? Is this OP’s first car?
Move_Over is offline   Reply With Quote
Old 03-30-2019, 06:28 PM   #27
ScaryFatKidGT
Drives: NGM SS 1LE
He is just telling the truth and making sense of what the op did, $1600 for the fronts maybe but the rears are like $100 each
I think so lol
2 Piece rotors only need the disks replaces, you don't need a new forged aluminum hat every time. How much are just the disks?
ScaryFatKidGT is offline   Reply With Quote
Old 03-30-2019, 07:01 PM   #28
Move_Over
Drives: ISO ss 1le
I think so lol
Mine were 239 and 269 on amazon.
