Old 03-24-2019, 10:25 AM   #15
laynlo15
Drives: 2022 Lt1 A10
Just had my passenger side replaced with the longer GM bolts in the TSB after one of our guys sheared his off playing around on the street.
Old 03-24-2019, 10:58 AM   #16
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
I am happy to report that my 2017 Camaro SS built Nov. 2016 has the fix with longer (68mm) bolts and Nordlock style washer!!
Here's some information that might help others:
  • Old bolt = 60.2mm (between 59.75mm and 60.8mm) in overall length including head of bolt which is ~10mm.
  • New bolt = ~67.8mm (between 57.5mm and 58.3mm) in overall length including head of bolt which is ~10mm.
  • The fix also contains the Nordlock style washers.
Information on the bolt length (old vs. new): https://www.camaro6.com/forums/showp...5&postcount=34
Information on TSB: https://www.cadillacforums.com/forum...formation.html
Good reference thread on this topic (where both links above were pulled): https://www.camaro6.com/forums/showthread.php?t=499904
I initially assumed I had the short bolts since mine don't stick out past the flange and end of bolt sits quite a bit inward. I had to measure mine with calipers to confirm it was in fact a 68mm bolt. I first measured from head of bolt to the edge of the axle flange. Then used a bent piece of metal to measure from edge of axle flange to back edge of bolt. I measured one on each side and got 67.77mm on one and 68mm on the other. The difference between long and short is pretty big (8mm), so the measurement does not have to be super precise to tell the difference between them.
Visually, mine looked exactly like Magnum922's pictures in the posts above. If you're not certain, I'd recommend measuring to make sure you don't waste money on the exact same bolt.
It's also worth noting that there might actually be a 3rd even longer bolt (see this thread) on the eLSD equipped cars (SS 1LE and ZL1): https://www.camaro6.com/forums/showp...0&postcount=46
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 03-24-2019, 02:06 PM   #17
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
I had it happen to me this week, at first they looked like warranty hopefully was going to cover it. But now they are saying the added power and mods void the warranty. Which I agree to a point, but I said this is happening to stock cars I am sure. It’s there excuse to screw me. I wish I had the number on how many Camaro owners are experiencing this.
Bolts backing out, come on GM and they are putting in longer bolts.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
