#15 |
![]() ![]() Drives: 2018 Redline Edition 2SS Join Date: Dec 2014
Makes my 555hp at the wheels look puny, thanks a lot....
2018 Redline Edition 2SS- A8, NPP, MRC, Recaro seats, ECS Novi 1500 tuned by EFX, cat deletes, Mighty Mouse Wild CC, GM STB, smoked ZL1 3rd brake light, Xpel XR Black 35% tint all around, Street Scene front splitter, C7 Carbon ZL1 side skirts Drake Muscle Car wicker bill, Adams Polishes Ceramic Coating
2010 Infiniti G37x Sedan for the DD. |
#16 |
![]() Drives: DZ Join Date: Aug 2018
#17 |
There are a couple of stations in NJ that have E85. The closest one to me is like 30 minutes away, definitely not worth it for me since I'm keeping the stock fuel system for now.
#18 |
@Blackmamba_1LE
Drives: 2017 1LE Join Date: Jun 2017
Wonder what I've i made this exact same setup + Ported MSD and headers..... Would it be to much, requiring me to go with less boost?
Also, how about LT4 everything but without the meth... you think the e85 + meth combo is necessary?
Florida High Performance: H/C Whipple LME 377 900WHP
#19 |
E85 and meth isn't needed unless you plan on running crazy boost IMO.
Still thinking of buying that kit we discussed in PM earlier?
#20 | |
My tuner said if we had headers on my car, he would have pursued tuning it with the 13-14lb setup we started with. For reference - when we tuned we mapped on 91 pump gas first, and Carl simply turned on the Alky system with factory settings and two 10# nozzles with strait meth and we picked up 70hp. We were in the 610s at the time. |
#21 | ||
@Blackmamba_1LE
#22 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Audi TT RS Join Date: Jan 2014
Very insteresting, albeit a stressful read. I may have missed it but, how was the intercooler and bypass setup like? That’s one reason I keep looking back at ProCharger. Centrifugal systems keep my attention because I don’t want a lot of low end grunt, like what I see from positive displacement systems.
2018 Audi TT ▊RS
2.4X 0-60, 1.6X 60', 120+mph 1/8th, 4.XX 60-130, 150+mph traps on 255/35/18 R888R tires on the street (unprepped). 2019 Audi RS3 About as fast as the TT RS 2019 Camaro ZL1 1LE Sold 2018 Camaro SS 1LE Sold 2019 Corvette Z06 Sold 2021 Charger Hellcat Redeye Widebody Sold |
#23 | |
On these torque based ECU systems you can manipulate the power curve via tuning the driver demand table and some other areas. Not to mention the Whipple 2.9 doesn't hit as hard down low as the smaller PD units. I am not saying to go Whipple because it's the best, but the all low end grunt talk is old mythology. This Whipple will make power clear on out to past 6500rpm easy on the SLB. My dyno pull was cut off at 6400 and it was still making power.
#24 |
I understand. What you’re saying isn’t lost on me but, I should also disclose that I refuse to run drag radials. More specifically to your point, the near instantaneous boost is what I would likely construe as the copious amounts of low end torque. As it stands currently, my car is useless on the low end, with just full bolt ons. Granted, again, I’m not using drag radials but, I’m also tuned by a very reputable tuner and despite our best efforts, my car still remains a bit off. There’s really no in between, unfortunately. As I mentioned in another thread, under light or moderate throttle, my car feels like it’s dragging a boat anchor. As soon as it hits about 3200rpm, it pulls hard and suddenly. Whereas under heavy throttle in the same range, it’s like my tires are covered in oil, it’s immediate and violent wheel spin. We’ve looked at the torque tables, traction control settings, cam timing, etc., it just keeps doing it. I’m thinking of just circumventing a lot of this and going with boost in the hopes to perhaps get a fresh set of eyes on the car and hopefully, get it to run right.
2018 Audi TT ▊RS
#25 |
You are going to hit some boost instantly regardless if it's a Centri or PD(I have owned both). The difference is you might only hit 4-5lbs on the hit of the throttle then build 2-3lbs towards peak rpm with a P1sc. With the Whipple I hit 7-8psi then builds to 9 peak.
The 555r is actually a very nice streetable tire imo. Its all around better then the stock run flat in ride, comfort, noise, and dry traction. If you drive your car daily rain or shine, then it might not be the best idea but they do ok in the rain if you keep your speed down.
#26 |
The intercooler and the belt drive system are the two reasons I went to the Vortech/ECS setup. They really don't have a "stage II" intercooler, they use the same one between the base kit and the 2000cfm kit.
It runs frame rail to frame rail, core support to the trans cooler (its larger than the radiator) ![]() As far as the tune on meth - it is NOT "meth dependent", I have plenty of fuel supply to support the system on E85 or Premium, we are just using the meth for temp control and a little octane. In 15 dyno pulls we used maybe a half a quart to 3/4 quart of methanol. |
#27 |
Thanks for the breakdown and image, DorkMissle. You certainly achieved a nice number with your setup. I won’t be running methanol or E85, however, just pump 93. I’d certainly like to keep boost under 10 psi, even with aftermarket pistons.
KingLT1, perhaps I didn’t explain the tire situation well enough but, I refuse to compromise my handling capabilities for straight line acceleration. I know there is going to be an absolute peak somewhere in the quest for more power while retaining tires designed for twisties. I still think many of my woes are tuning related so, I think it’s a matter of tracking another tuner down and explaining to them what was tried and where we left off—then hoping for the best. But that’s going to have to wait til later on this year.
2018 Audi TT ▊RS
#28 |
I had ECS install my kit themselves, with their tune I hit 555hp and 528tq at the wheels on an otherwise stock car aside from deleting the secondary cats(not really a mod for horsepower). 93 octane, stock fuel system, the regular 8# pulley.
