Old 03-19-2019, 09:15 PM   #15
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Got virgin can of ate200 sitting on shelf, will have to add that to do list.
ing for grip.
http://www.motorsportsne.com/
Old 03-19-2019, 10:36 PM   #16
Apexslayer
Drives: Zl1 1le
If you are doing any track work go with SRF or RBF. The Castrol is expensive but will last the entire year, the RBF is cheaper but probably needs to be changed after every 2 to 4 track weekends.
I'm lazy - I go with the SRF.
Apexslayer is offline   Reply With Quote
Old 10-29-2021, 01:57 PM   #17
CLARKPRIDE
CLARKPRIDE's Avatar
Drives: Chevrolet Camaro SS 2011
Where do you guys buy your Castrol SRF, online?
CLARKPRIDE is offline   Reply With Quote
Old 10-30-2021, 07:03 AM   #18
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
amazon
Old 10-30-2021, 04:47 PM   #19
Apexslayer
Drives: Zl1 1le
Originally Posted by UrbanKnight View Post
Stock fluid is garbage for track use. GM even says so in their track supplement. Buy Castrol SRF, change once a year. Your car will thank you.
Buy Castrol SRF, change once a year. You will thank you!
Old 10-30-2021, 04:51 PM   #20
Apexslayer
Drives: Zl1 1le
Originally Posted by Checkmate1 View Post
How many Liters of SRF do you reckon will be required for a brake fluid flush?
Usually 1 litre. Once, not sure why, but the dealer needed a little more than 1. So I used the remainder of the second bottle in another vehicle.
Old 10-30-2021, 05:17 PM   #21
2004YZFR1
Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE
The Castrol SRF says to change the fluid every 18 months max use. Of course it would be better to change it more often if you track the car multiple times per year.
2004YZFR1 is offline   Reply With Quote
Old 10-31-2021, 04:26 PM   #22
Heartbreaker
Heartbreaker's Avatar
Drives: 2020 Camaro ZL-1 1LE
+1
Castrol SRF, the best and longest lasting
Home Track: NCM Motorsports Park
Heartbreaker is offline   Reply With Quote
Old 10-31-2021, 09:15 PM   #23
20Bluezl1
SRF all the way, 1st time switching over I bought to bottles and used 1½ I made sure I bleed out all the old fluid. Tbe rest of the bottle I use to bleed every 3 or 4 events.
Old 11-01-2021, 07:38 AM   #24
infinitereality
Limitless Imagination
infinitereality's Avatar
Drives: 2018 ZL1 & 2022 Hayabusa
I don't track my car, at least not yet, but still have stock fluid. Figure it's due for a change and upgrade since it's easy. Is the most efficient way to swap fluid is with a Power Bleeder?
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof
- Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED
- RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook
- Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin
2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels
- +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc...
infinitereality is offline   Reply With Quote
