#15 | |
![]() Drives: 2018 ZL1 1LE, 2014 ZL1 Join Date: Jul 2017
#16 |
![]() ![]() ![]() ![]() Drives: 1LEs Join Date: May 2009
https://www.camaro6.com/forums/showthread.php?t=500815
SS not ZL1 but check same area just in case... |
#17 | |
#18 |
Just dropped it off at the shop, Back up camera is also not working. Ill post up the solution shortly
#19 |
UPDATE: Problem fixed... burnt through a wiring harness tie clip which cause the wiring harness to melt through 6 of the wires. Additionally, ended up blowing 5 or so fuses in the process.. Talked to my dealer, wont cover on the warranty due to the headers..
#20 |
Drives: 2019 Dodge Challenger Scat Pack Join Date: Apr 2014
Yeah, that's what I figured, burnt the wires and shorted multiple fuses in the process. I imagine there's some protection you can use around that to prevent the excessive heat.
#21 |
![]() ![]() ![]() ![]() Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
I would go back to the shop that installed the headers. They should have noticed a wiring harness was too close to them and either fixed it or made you aware of it, so you could!
#22 |
![]() Drives: 2018 Camaro ZL1 1LE Join Date: Apr 2015
Pics of where it was touching
#23 |
#24 |
Was it the area per the link I sent? Wondering as headers may be in my near future...
#25 |
It is the wiring harness under the coolant reservoir that is secured to the frame rail. The zip ties broke and fell onto the headers and hence the electrical nightmare ensued. Back up and running thanks to Aikman Performance in ATX
. Harness was rerouted and secured with metal zip ties!
#26 |
Glad to hear you got this fixed Greg... I really hate the plastic zip tie thing. Just a recipe for disaster.
Nice to have a shop that takes care of you too
#27 |
#28 | |
I always coat my headers and also wrap near. On my cars with coated headers, within a short time, you could touch the headers after running...yes, still hot, but, WAY lower temp and radiant heat off them. Might have saved my Firebird years ago from burning up when I kicked rods out at almost 150mph and oil got on them even with an engine diaper. Surprised so few guys get headers high temp coated...not saying you can lay plastic loomed wiring against coated headers, just saying it greatly lowers the outside temp of the piping. |
| Tags |
| 1le, electrical, issue, problems, zl1 |
