#15 |
![]() Drives: 2019 2SS Riverside Blue Metallic Join Date: Sep 2018
Updating from my morning drive. Squeak was barely audible, I did notice significant buildup in the exhaust pipe and on the valves themselves, like pitch black, so I'll be spraying them down tonight and giving them a good clean as safely as possible.
The squeak is only when the valve closes and does not squeak when opening, completely the opposite of my original problem with the first exhaust. I could not hear anything with the windows down and driving, however it was audible when parked, but not any worse than with the windows up. Will clean tonight and update again.
Order # WKXN0F 2SS Riverside Blue Metallic, A10, NPP, 56V
Ordered 9/15/18 1100......9/17/18 3000......9/19/18 TPW: 11/26/18 3300......11/9/18 TPW: 11/26/18 3400......11/12/18 TPW: 11/26/18 4300......11/22/18 BUILT! VIN: 1G1FH1R72K0123562 4B00......11/27/18 Waiting for Dispatch! Tentative delivery date of 12/11! 4300......11/28/18 Waiting for the train to Florida! 4200......12/5/18 SHIPPED! 4800......12/14/18 5000/6000......12/18/18 SHE'S HOME BOYS! Follow me on Instagram! @the_3ngin33r |
#16 |
![]() Drives: 2019 2SS A10 Shadow Gray Join Date: May 2014
Sorry to hear this, dealing with the same thing here.
I also hear mine constantly in California traffic as it is transitioning from V8 to V4. |
#17 | |
I would find a dealer willing to work with you. Just be upfront, show them the forum postings and what was done. My dealer didn't hesitate with the original exhaust, they performed the recommend service twice and when it failed the third time, they contacted GM to authorize the exhaust replacement.
#18 |
![]() Drives: 2016 Camaro 2SS M6 Join Date: Mar 2019
Any reason you dont want to just pull the NPP fuse? It will be loud all the time.
#19 |
I paid for the ability to have my exhaust be quiet when I want it to and loud when I want it to. Why would I not want to get what I paid for?
#20 |
Sad update, cleaning out the build up did not fix it. I ordered a can of the dry lubricant that was used before, and I'll give lubricating it a try. If it doesn't work, I may do a fuse pull or just live with it.
#21 |
Happy update. The lubrication seems to have nearly quieted the squeak. I am going to do another lube of it tonight when the exhaust is stone cold, and I am fairly certain that will make the problem go away.
The TSB that has the work instructions isn't complete. You need to also lube the moving parts on the inside of the exhaust. This would explain why the lubing had no effect on my first exhaust. This should probably be regular maintenance for anyone with NPP. I'll update again after a week.
#22 | |
Good to hear its better! |
#23 |
![]() Drives: 2023 Chevrolet Camaro LT1 RS Join Date: Sep 2023
Although no permanent solution was ever really found, I noticed even my 2023 LT1 with NPP start doing this when I switched the modes randomly around 15k miles, and now at 22k miles it squeaks all the time; when I switch modes and as it opens/closes depending on throttle.
Pulling the fuse is cool and all at times, but gets annoying over time for a few different reasons. Even though I feel bad that many of us are experiencing this with our sweet baby’s, this thread with frequent updates has been one of the funniest [and still helpful] that I’ve seen on here yet… 😂😂 I do appreciate your tips and outcomes of the potential fixes for this, though. Pretty dope GM is cool enough to replace the whole exhaust if the severity is taken that far!
Sullins
#24 |
I chopped off the "legs" of the actuators on both sides as per this TSB, plus I lubricate once every 6 months or so with Drislide as per this other TSB. My NPP valves are still as quiet as when they were new.
